1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: pyepics bug (need fix asap!) + Matthew Newville?
To: EPICS tech-talk <[email protected]>
Date: Tue, 21 Sep 2010 22:27:50 -0700
Hello,
I have been using epics and python for quite some time now.
Just recently I moved to the excellent pyepics.
The only issue... long type PVs!
I am about to upgrade to the latest version (pyepics 3,0,8) since I am using an older one (3.0.1)
But here is what I see:
epics2@cr1com1 $ caget DMC2183:1:AEncdrPstnLI
DMC2183:1:AEncdrPstnLI         -1833
in python:
-------> print(pv.info)
== DMC2183:1:AEncdrPstnLI  (long) ==
   value      = 4294965463
   char_value = 4294965463
   count      = 1
   type       = long
   units      = Steps
   host       = cls1ir-eth0:5064
   access     = read/write
   status     = 0
   severity   = 0
   timestamp  = 1285131880.264 (2010-09-21 22:04:40.263942)
   upper_ctrl_limit    = 0
   lower_ctrl_limit    = 0
   upper_disp_limit    = 0
   lower_disp_limit    = 0
   upper_alarm_limit   = 0
   lower_alarm_limit   = 0
   upper_warning_limit = -7872675053568
   lower_warning_limit = 0
   PV is internally monitored, with 0 user-defined callbacks:
Notice the reported value as ...
   value      = 4294965463
It seems there is an issue with bit ordering.
It works well for double records though.s ;-)
Based on the pdf doc, the maintainer is Matthew Newville at U Chicago.
Is he on the mailing list? Anyone knows how to contact him?
I should have contacted him a long time ago....
Best,
Emmanuel
Emmanuel
Re: pyepics bug (need fix asap!) + Matthew Newville? Matt Newville
Prev: Re: vlinac and point release Eric Norum
Next: Re: pyepics bug (need fix asap!) + Matthew Newville? Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Register at http://www.bnl.gov/guv/gis.asp Dalesio, Leo
ANJ, 22 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
