1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pyepics bug (need fix asap!) + Matthew Newville?
To: EPICS tech-talk <[email protected]>
Date: Wed, 22 Sep 2010 06:38:11 -0500
Hi Emmanuel,
Sorry for the trouble (and I do read tech-talk, sometimes early in the
morning).  I don't see that behavior, at least on the first machine I
tested it on (linux-x86).  Using both python2.6 and python3.1, I get
the expected values for longs:
millenia:~>caget 13XRM:m1.RRBV
13XRM:m1.RRBV                  -20000
millenia:~>python
Python 2.6 (r26:66714, Nov  3 2009, 17:33:38)
[GCC 4.4.1 20090725 (Red Hat 4.4.1-2)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
Imported history from: '/home/newville/.pyhist'
>>> import epics
>>> epics.__version__
'3.0.8'
>>> p = epics.PV('13XRM:m1.RRBV')
>>> print p.info
== 13XRM:m1.RRBV  (native_long) ==
   value      = -20000
   char_value = '-20000'
   count      = 1
   type       = long
   units      = mm
   host       = sonata.cars.aps.anl.gov:5064
   access     = read-only
   status     = 0
   severity   = 0
   timestamp  = 1285154637.998 (2010-09-22 06:23:57.998245)
   upper_ctrl_limit    = 1240000
   lower_ctrl_limit    = -1240000
   upper_disp_limit    = 1240000
   lower_disp_limit    = -1240000
   upper_alarm_limit   = 0
   lower_alarm_limit   = 0
   upper_warning_limit = 0
   lower_warning_limit = 0
   PV is internally monitored, with 0 user-defined callbacks:
I don't think it's an issue with the version of pyepics, as nothing
has changed in the mapping of the Epics database types to the  python
ctypes types:  An Epics DBR_LONG becomes a ctypes.c_long.
What system are you working on, and how were Epics base and python
built? Could this be an issue with 64bit machines?
Sorry for the trouble,
--Matt Newville <newville at cars.uchicago.edu> 630-252-0431
On Wed, Sep 22, 2010 at 12:27 AM,  <[email protected]> wrote:
> Hello,
> I have been using epics and python for quite some time now.
> Just recently I moved to the excellent pyepics.
> The only issue... long type PVs!
> I am about to upgrade to the latest version (pyepics 3,0,8) since I am using an older one (3.0.1)
> But here is what I see:
> epics2@cr1com1 $ caget DMC2183:1:AEncdrPstnLI
> DMC2183:1:AEncdrPstnLI         -1833
> in python:
> -------> print(pv.info)
> == DMC2183:1:AEncdrPstnLI  (long) ==
>   value      = 4294965463
>   char_value = 4294965463
>   count      = 1
>   type       = long
>   units      = Steps
>   host       = cls1ir-eth0:5064
>   access     = read/write
>   status     = 0
>   severity   = 0
>   timestamp  = 1285131880.264 (2010-09-21 22:04:40.263942)
>   upper_ctrl_limit    = 0
>   lower_ctrl_limit    = 0
>   upper_disp_limit    = 0
>   lower_disp_limit    = 0
>   upper_warning_limit = -7872675053568
> Notice the reported value as ...
>   value      = 4294965463
> It seems there is an issue with bit ordering.
> It works well for double records though.s ;-)
> Based on the pdf doc, the maintainer is Matthew Newville at U Chicago.
> Is he on the mailing list? Anyone knows how to contact him?
> I should have contacted him a long time ago....
> Best,
> Emmanuel
> Emmanuel
Re: pyepics bug (need fix asap!) + Matthew Newville? emmanuel_mayssat
Prev: pyepics bug (need fix asap!) + Matthew Newville? emmanuel_mayssat
Next: Re: vlinac and point release J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: pyepics bug (need fix asap!) + Matthew Newville? emmanuel_mayssat
ANJ, 22 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
