1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: SNS CSS Update, BOY Image Viewer, CSS on 64 bit
To: EPICS tech-talk <[email protected]>
Date: Fri, 24 Sep 2010 09:08:15 -0400
Hi:
In http://www.aps.anl.gov/epics/tech-talk/2010/msg01457.php, Xihui reported
on an improvement in the BOY image viewer (Intensity Graph) memory usage.
That's now included in the current SNS products.
Other updates in there which will also be in products from other sites that
use the 'current' CSS sources:
* Data Browser: Value axes can be 'invisible' to increase plot area
* Probe: Fix for EPICS R3.14.11 alarm limit behavior
  (were undefined limits are NaN)
* Channel Access: Updated to 2009/09/14 source snapshot of
  JCA 2.3.3 and CAJ 1.1.6 from http://epics-jca.sourceforge.net
Update regarding CSS not running on 64 bit machines,
http://www.aps.anl.gov/epics/tech-talk/2010/msg01352.php
This now hit us at the SNS in the form of Windows 7 users who had only
installed the 64 bit version of Java.
As reported in previous posts, it should be possible to install a 32 bit
version of Java and then all is OK. For example, on Windows 7 one can
install both this VM:
java.version=1.6.0_21
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
... and this one:
java.version=1.5.0_17
java.vm.name=Java HotSpot(TM) Client VM
With that in place, the 'usual' Win32 version of CSS will run OK,
automagically selecting the 32 bit JVM. Same is possible on Linux. The Mac
OS JVM has a "-d32" command line option to enforce 32 bit operation.
Nevertheless we now have Windows 7 users who only have the 64 bit JVM
installed, and for those we build a version of CSS with a native 64 bit
launcher.
Kay
Prev: RE: Soft IOCs and Port Numbers Jeff Hill
Next: Re: [Fwd: RE: Soft IOCs and Port Numbers] Pam Gurd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Soft IOCs and Port Numbers Ralph Lange
ANJ, 24 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
