1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Soft IOCs and Port Numbers
To: EPICS Tech Talk <[email protected]>
Date: Fri, 24 Sep 2010 12:14:41 -0400
On 24.09.2010 11:34, Eric Norum wrote:
We run multiple soft IOCs on the same linux box all the time. They each get a port assigned by the kernel. caRepeater takes care of fanning out the UDP requests for PV information.
caRepeater fans out beacon messages to multiple clients on one machine. It has *nothing* to do with name resolution on the server machine.
It does take care of the same problem, i.e. UDP messages not reaching all processes that want to receive them. But, again: it does it on the client side for the UDP beacons (default port 5065), not on the server side for the UDP name resolution (default port 5064), which is the issue here.
Ralph
Soft IOCs and Port Numbers Pam Gurd
Re: Soft IOCs and Port Numbers Eric Norum
Prev: Re: Soft IOCs and Port Numbers Andrew Johnson
Next: Re: Soft IOCs and Port Numbers Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Soft IOCs and Port Numbers Richard Farnsworth
Next: SNS CSS Update, BOY Image Viewer, CSS on 64 bit Kasemir, Kay
ANJ, 27 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
