1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Soft IOCs and Port Numbers
To: Eric Norum <[email protected]>
Cc: [email protected]
Date: Fri, 24 Sep 2010 10:52:30 -0500
On Friday 24 September 2010 10:34:28 Eric Norum wrote:
> I don't understand the issue.
> We run multiple soft IOCs on the same linux box all the time.   They each
> get a port assigned by the kernel.  caRepeater takes care of fanning out
> the UDP requests for PV information. "It just works".
... unless someone configures a client with EPICS_CA_AUTO_ADDR_LIST=NO and
EPICS_CA_ADDR_LIST pointing to the IP address of that linux box.  With that
configuration each individual CA name search UDP message gets routed by the IP
kernel to only one of the IOCs, and depending on the particular kernel that
might always be the same IOC (thus hiding the other IOCs from that client) or
it might round-robin between IOCs, making connection times longer.
One solution that I don't think anyone has suggested yet would be to run a CA
name-server on each IOC box at the official port number, and have it know
about and forward searches to all the IOCs on that particular box, or use the
"dbl > file" approach on each IOC so the name-server knows all the PVs
directly.  This needs no special configuration on the part of the clients,
they can use broadcasts or directed UDP as they wish, and there's no single
point of failure for the control system as a whole (assuming the name servers
get started when each machine comes up).
- Andrew
The best FOSS code is written to be read by other humans -- Harald Welte
Re: Soft IOCs and Port Numbers Eric Norum
Soft IOCs and Port Numbers Pam Gurd
Prev: Re: Soft IOCs and Port Numbers Eric Norum
Next: Re: Soft IOCs and Port Numbers Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Soft IOCs and Port Numbers Eric Norum
ANJ, 24 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
