1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: vlinac and point release
From: "Akridge, Charles S. (MSFC-ES52)" <[email protected]>
To: Andrew Johnson <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 24 Sep 2010 15:15:35 -0500
Andrew,
I downloaded the new version, unzipped and double-clicked on
startIoc.command. This is the error message I received from the terminal:
--- begin -----
x-asset-user-Q40-2:~ cakridge$
/Users/cakridge/Desktop/PDAS/EPICS/vlinac/vlinac/startIoc.command ; exit;
dyld: Library not loaded: /sw/lib/libreadline.5.dylib
  Referenced from:
/Users/cakridge/Desktop/PDAS/EPICS/vlinac/vlinac/lib/darwin-x86/libca.3.14.1
1.dylib
  Reason: image not found
  Referenced from:
/Users/cakridge/Desktop/PDAS/EPICS/vlinac/vlinac/lib/darwin-x86/libseq.3.14.
11.dylib
Trace/BPT trap
logout
--- end ---
Thank for the help.
Scott
> From: Andrew Johnson <[email protected]>
> Date: Tue, 21 Sep 2010 12:43:37 -0500
> To: "[email protected]" <[email protected]>
> Cc: "[email protected]" <[email protected]>
> Hi Scott,
> I updated, rebuilt and uploaded the vlinac_multi.tgz file, apologies that it's
> 20MB but it does include binaries and library files for all the Unix-like
> architectures we support.  Most of the start* scripts needed modifications to
> add support for some newer architectures, I hope they should all work,
> although I haven't tested them all.
>     http://www.aps.anl.gov/epics/download/examples/vlinac_multi.tgz
> Note that MEDM, ALH and StripTool are all fairly old tools now and a more
> modern example would probably use CS-Studio for the operator GUIs.
> - Andrew
> On Monday 20 September 2010 17:38:28 Akridge, Charles S. (MSFC-ES52) wrote:
>> Downloaded and attempted to run ³startProbe.command² but found out that the
>> build is for PowerPC not Intel. I have a MacBook Pro running MacOSX 10.6.4
>> and would prefer to get a point release for this Mac but if not I need I
>> need to understand how to compile vlinac for this machine.
>> BTW, I¹m rusty on reading a makefile so any step-by-step instructions or
>> better yet a point release would be great.
>> Scott
> The best FOSS code is written to be read by other humans -- Harald Welte
Re: vlinac and point release Stephen Lewis
Re: vlinac and point release J. Lewis Muir
Re: vlinac and point release Andrew Johnson
Prev: Re: Soft IOCs and Port Numbers Andrew Johnson
Next: Re: vlinac and point release Stephen Lewis
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: vlinac and point release J. Lewis Muir
ANJ, 24 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
