1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: vlinac and point release
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 24 Sep 2010 15:29:37 -0500
On 9/24/10 3:15 PM, Akridge, Charles S. (MSFC-ES52) wrote:
> Andrew,
> I downloaded the new version, unzipped and double-clicked on
> startIoc.command. This is the error message I received from the terminal:
> --- begin -----
> x-asset-user-Q40-2:~ cakridge$
> /Users/cakridge/Desktop/PDAS/EPICS/vlinac/vlinac/startIoc.command ; exit;
> dyld: Library not loaded: /sw/lib/libreadline.5.dylib
>   Referenced from:
> /Users/cakridge/Desktop/PDAS/EPICS/vlinac/vlinac/lib/darwin-x86/libca.3.14.1
> 1.dylib
>   Reason: image not found
>   Referenced from:
> /Users/cakridge/Desktop/PDAS/EPICS/vlinac/vlinac/lib/darwin-x86/libseq.3.14.
> 11.dylib
> Trace/BPT trap
> logout
> --- end ---
> Thank for the help.
> Scott
Hi, Scott.
It looks like it can't find the readline library.  But this was just
asked about earlier in this thread.  Did you try installing Fink and
then installing the readline package (as mentioned by Eric Norum)?
It would probably be nicer if the vlinac binary package could contain
the readline library or have it disabled so that a user doesn't have to
install any extra software.  Including it is more work, and I don't know
if licensing-wise it's OK, but it would be nicer.
Lewis
Re: vlinac and point release Andrew Johnson
Re: vlinac and point release Akridge, Charles S. (MSFC-ES52)
Prev: Re: vlinac and point release Stephen Lewis
Next: Re: vlinac and point release Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: vlinac and point release Akridge, Charles S. (MSFC-ES52)
ANJ, 24 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
