1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: vlinac and point release
From: "Akridge, Charles S. (MSFC-ES52)" <[email protected]>
To: Stephen Lewis <[email protected]>
Date: Fri, 24 Sep 2010 17:04:51 -0500
Stephen,
Got it!!! At least everything is up and running. Need to check it out more
fully and understand next.
Thank you (and Andrew) for the help.
Scott
> From: Stephen Lewis <[email protected]>
> Date: Fri, 24 Sep 2010 15:27:41 -0500
> To: "[email protected]" <[email protected]>
> Cc: Andrew Johnson <[email protected]>, "[email protected]"
> <[email protected]>
> /sw/lib is where the fink package puts libraries.
> I had to install fink and then 'fink install readline5'.  This is sufficient
> to run the IOC.
> I also installed openmotif4.  medm ran fine but probe and alh did't.  Eric
> Norum said to use openmotif3, not openmotif4.  So I uninstalled openmotif4 and
> installed openmotif3, however, now they all are looking for
> '/sw/lib/libXm.4.dylib'.
> On 24 Sep 2010, at 13:15 , Akridge, Charles S. (MSFC-ES52) wrote:
>> Andrew,
>> I downloaded the new version, unzipped and double-clicked on
>> startIoc.command. This is the error message I received from the terminal:
>> --- begin -----
>> x-asset-user-Q40-2:~ cakridge$
>> /Users/cakridge/Desktop/PDAS/EPICS/vlinac/vlinac/startIoc.command ; exit;
>> dyld: Library not loaded: /sw/lib/libreadline.5.dylib
>>  Referenced from:
>> /Users/cakridge/Desktop/PDAS/EPICS/vlinac/vlinac/lib/darwin-x86/libca.3.14.1
>> 1.dylib
>>  Reason: image not found
>>  Referenced from:
>> /Users/cakridge/Desktop/PDAS/EPICS/vlinac/vlinac/lib/darwin-x86/libseq.3.14.
>> 11.dylib
>> Trace/BPT trap
>> logout
>> --- end ---
>> Thank for the help.
>> Scott
>>> From: Andrew Johnson <[email protected]>
>>> Date: Tue, 21 Sep 2010 12:43:37 -0500
>>> Cc: "[email protected]" <[email protected]>
>>> Hi Scott,
>>> I updated, rebuilt and uploaded the vlinac_multi.tgz file, apologies that
>>> it's
>>> 20MB but it does include binaries and library files for all the Unix-like
>>> architectures we support.  Most of the start* scripts needed modifications
>>> to
>>> add support for some newer architectures, I hope they should all work,
>>> although I haven't tested them all.
>>>    http://www.aps.anl.gov/epics/download/examples/vlinac_multi.tgz
>>> Note that MEDM, ALH and StripTool are all fairly old tools now and a more
>>> modern example would probably use CS-Studio for the operator GUIs.
>>> - Andrew
>>> On Monday 20 September 2010 17:38:28 Akridge, Charles S. (MSFC-ES52) wrote:
>>>> Downloaded and attempted to run ³startProbe.command² but found out that the
>>>> build is for PowerPC not Intel. I have a MacBook Pro running MacOSX 10.6.4
>>>> and would prefer to get a point release for this Mac but if not I need I
>>>> need to understand how to compile vlinac for this machine.
>>>> BTW, I¹m rusty on reading a makefile so any step-by-step instructions or
>>>> better yet a point release would be great.
>>>> Scott
>>> The best FOSS code is written to be read by other humans -- Harald Welte
Re: vlinac and point release Stephen Lewis
Prev: Re: vlinac and point release Andrew Johnson
Next: ImageMagick Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: vlinac and point release Stephen Lewis
Next: Re: vlinac and point release J. Lewis Muir
ANJ, 24 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
