1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ImageMagick
To: <[email protected]>
Date: Fri, 24 Sep 2010 17:49:39 -0500
Folks,
Uwe Flechig from PSI recently introduced me to the ImageMagick software suite.
http://www.imagemagick.org/
One of the things it provides is a C++ library that is very simple and powerful.  For example, the following 3 lines of code will read any URL containing an image in any of dozens of formats, rotate it 90 degrees and save it as a TIFF file:
        Image image("http://www.solarstrahlung-dietzenbach.de/images/sonne.jpg";);
        image.rotate(90.);
        image.write("test.tiff");
This is so much simpler and more powerful than using the libtiff and libjpeg libraries directly that I am very interesting in switching to it for areaDetector.  One of the next detector drivers I am thinking of writing, partly at Uwe's suggestion, is a driver for Web cameras and Axis video Web servers.  This would allow areaDetector to get images from existing analog cameras via MJPEG, decompress them, and the use the statistics and processing plugins, for example.  This would be trivial with ImageMagick using the URL in a constructor as shown above (or in the Image.read method).
My question is whether anyone in this group has experience with it, and knows of any potential problems.  It runs on Linux, Windows and Mac.  I got it running quickly on Linux, but on Windows I seem to have problems reading disk files my own software, though their command line utilities work.
RE: ImageMagick tom.cobb
Prev: Re: vlinac and point release Akridge, Charles S. (MSFC-ES52)
Next: Long string ... emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: procServ, not CA Re: [Fwd: RE: Soft IOCs and Port Numbers] Steven M. Hartman
Next: RE: ImageMagick tom.cobb
ANJ, 27 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
