1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ImageMagick
To: <[email protected]>, <[email protected]>
Date: Mon, 27 Sep 2010 09:13:42 +0100
I'm currently using the ffmpeg[1] libraries in a QT based viewer to
decompress and display the mjpg stream produced by ffmpegServer[2]. I
have also tested the viewer with the axis webcams mjpg stream. It's not
the nicest API, but it is a lot more efficient than the libjpeg
libraries I was using previously. It's about 20 lines of code to
connect, decompress, and convert an mjpg stream to RGB or mono frames,
and the code is listed in ffmpegServer/Viewers/ffmpegServer.cpp. It
works on Linux and windows, haven't tried Mac yet...
[1] http://ffmpeg.org/
[2] http://controls.diamond.ac.uk/downloads/support/ffmpegServer/
Tom Cobb,
Diamond Light Source Ltd.
Diamond House
Harwell Science and Innovation Campus
Didcot
Oxfordshire
OX11 0DE
Tel +44 (0) 1235 778582
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Mark Rivers
> Sent: 24 September 2010 23:50
> To: [email protected]
> Subject: ImageMagick
> Folks,
> Uwe Flechig from PSI recently introduced me to the
> ImageMagick software suite.
> http://www.imagemagick.org/
> One of the things it provides is a C++ library that is very
> simple and powerful.  For example, the following 3 lines of
> code will read any URL containing an image in any of dozens
> of formats, rotate it 90 degrees and save it as a TIFF file:
>         Image
> image("http://www.solarstrahlung-dietzenbach.de/images/sonne.jpg";);
>         image.rotate(90.);
>         image.write("test.tiff");
> This is so much simpler and more powerful than using the
> libtiff and libjpeg libraries directly that I am very
> interesting in switching to it for areaDetector.  One of the
> next detector drivers I am thinking of writing, partly at
> Uwe's suggestion, is a driver for Web cameras and Axis video
> Web servers.  This would allow areaDetector to get images
> from existing analog cameras via MJPEG, decompress them, and
> the use the statistics and processing plugins, for example.
> This would be trivial with ImageMagick using the URL in a
> constructor as shown above (or in the Image.read method).
> My question is whether anyone in this group has experience
> with it, and knows of any potential problems.  It runs on
> Linux, Windows and Mac.  I got it running quickly on Linux,
> but on Windows I seem to have problems reading disk files my
> own software, though their command line utilities work.
> Thanks,
> Mark
ImageMagick Mark Rivers
Prev: Re: StreamDevice slowdown Eric Norum
Next: Re: StreamDevice slowdown Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ImageMagick Mark Rivers
Next: Long string ... emmanuel_mayssat
ANJ, 27 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
