1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: StreamDevice slowdown
To: "Eric Norum" <[email protected]>, "Dirk Zimoch" <[email protected]>, <[email protected]>
Date: Sun, 26 Sep 2010 18:17:03 -0500
So do you have a workaround?  Use streamDevice for everything except the waveform, and the asyn record for that?
Sent: Sun 9/26/2010 5:41 PM
To: Mark Rivers; Dirk Zimoch; [email protected] tech-talk
Subject: Re: StreamDevice slowdown
Hmm...
I have an asyn record in my application already.
So, I set up a bug buffer when I instantiate it:
dbLoadRecords "db/asynRecord.db" "P=tfb:,R=asyn,PORT=L0,ADDR=-1,OMAX=0,IMAX=33554432"
Then at the end of the st.cmd file:
dbpf tfb:arm Arm
DBR_STRING:          "Arm"
epicsThreadSleep 1
dbpf tfb:softTrigger 1
DBR_STRING:          "Trigger"
epicsThreadSleep 1
dbpf tfb:asyn.OFMT ASCII
DBR_STRING:          "ASCII"
dbpf tfb:asyn.IFMT Binary
DBR_STRING:          "Binary"
dbpf tfb:asyn.AOUT "Waveform?"
DBR_STRING:          "Waveform?"
And the 'seconds per megasample'  are:10.24
10.24
10.25
10.25
10.24
10.25
10.24
10.25
10.24
10.24
10.25
10.25
10.24
10.24
10.25
10.24
So, the smoking gun appears to be in StreamDevice's hand.....
On Sep 26, 2010, at 3:29 PM, Mark Rivers wrote:
> To be sure that the problem is streamDevice rather than something else in EPICS, you could use the asynRecord to do the tests.  Put the OFMT=ASCII, IFMT=Binary, and make the IMAX be large enough to hold your waveform when you boot the IOC.
> Mark
> ________________________________
> From: Eric Norum [mailto:[email protected]]
> Sent: Sun 9/26/2010 5:25 PM
> To: Mark Rivers
> Cc: [email protected]; Dirk Zimoch
> To check the raw transfer speed I did:
>         telnet  -c  192.168.1.159 73 >/dev/null
> and typed in the 'Waveform?\n" command.
> The times per megasample for 16 megasamples in this case:
> 10.25
> 10.24
> 10.24
> 10.25
> 10.24
> 10.25
> 10.24
> 10.25
> 10.24
> 10.25
> 10.24
> 10.25
> 10.24
> 10.25
> 10.24
> 10.24
> So I'm pretty sure that the slowdown is in the StreamDevice processing somewhere.
> By way of comparison, here are the 16 'seconds per megasample' values when using ASYN/StreamDevice rather than telnet:
> 16.78
> 48.18
> 80.91
> 113.86
> 147.28
> 180.20
> 211.65
> 244.36
> 278.61
> 308.90
> 342.91
> 374.54
> 408.60
> 439.26
> 473.29
> 505.54
> On Sep 26, 2010, at 2:40 PM, Mark Rivers wrote:
>> Have you turned on asynTrace in the low-level (TCP?) driver and sent the output to a file so it does not slow things down too much?  Can you see then what's on the wire?
>> Mark
> Eric Norum
> [email protected]
Eric Norum
[email protected]
Re: StreamDevice slowdown Eric Norum
RE: StreamDevice slowdown Mark Rivers
Prev: Re: StreamDevice slowdown Eric Norum
Next: Re: StreamDevice slowdown Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 26 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
