1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: archiving system
To: Dirk Martin <[email protected]>
Date: Tue, 28 Sep 2010 10:40:37 -0400
Dirk,
James Rowland from Diamond recently did a poll and has the most current list of archiving solutions that are used with EPICS. I think he will talk about it at the upcoming EPICS Collaboration Meeting in two weeks.
My first order answer would be:
There's the Channel Archiver: old, stable, fast, very widely used, but not based on a RDB.
There are several other archiving solutions, some of which use a RDB for storage, others don't. Different ages, different languages, different file formats or RDB systems for storage. Their common feature: they are all used at one lab only, two labs maximum.
CSS databrowser support is available for the Channel Archiver, and for the Oracle-based archiver at SNS. (The latter might not be part of the DESY CSS.) There is experimental support for HyperArchiver (Channel Archiver writing into Hypertable).
While RDB-based archiving solutions have a tendency to be slower (as well in writing an archive as retrieving from it), I don't see an issue here for your system (unless your 10K channels are updating every second or faster).
Hope this helps,
Ralph
On 28.09.2010 10:23, Dirk Martin wrote:
Hallo,
at the S-DANILAC of the TU Darmstadt we're using EPICS to control power
supplies for example. Since it is necessary to observe ~10000 PVs for a
period of nearly four weeks, we decided to introduce an archiving system
based upon a relational database. We're using CSS (from the DESY) and
would like to plot the archived data in the Data Browser.
That is why I ask you, whether you could tell me, which archiving system
is wide-spreaded enough and best for this job.
Thanks in advance and best regards
Dirk Martin
Re: archiving system Jack
RE: archiving system james.rowland
archiving system Dirk Martin
Prev: archiving system Dirk Martin
Next: Re: error compiling base R3-14-11 J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: archiving system Jack
ANJ, 28 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
