On 9/28/10 4:37 AM, gabriele marano wrote:
> Hi,
> An error occurs when I try to install base R3-14-11 on Ubuntu (GNU make
> vers is: 3.81-7):
Hi, Gabriele.
Which version of Ubuntu?
> “../src/libCom/osi/os/default/epicsReadline.c:76:31: error:
> readline/readline.h: Nessun file o directory”
I'm guessing "Nessun file o directory" is Italian for "No file or
directory". So it can't find readline.h.
> readline- devel package is already installed.
On Ubuntu 8.04 (very old now), I needed to install libreadline5-dev.
This package is in the main repository. It provides readline.h at
/usr/include/readline/readline.h. Does readline.h exist on your system
at that location? If not, can you see if there is a libreadline5-dev,
or perhaps a libreadline6-dev package available, and install it?
> Anyway,
> I placed the unpacked folder in C:\base-R3-14-11.
That doesn't look like a Unix path. I thought you were doing this in
Ubuntu (?).
> EPICS_ARCH_HOST exists and is ok. I didn’t modify anything else.
The environment variable name should be EPICS_HOST_ARCH, not
EPICS_ARCH_HOST. In a Bourne shell, you should have done something like
this for a 32-bit Linux:
export EPICS_HOST_ARCH=linux-x86
or for a 64-bit Linux:
export EPICS_HOST_ARCH=linux-x86_64
> from terminal à make and then error. Can you help me?
Try the steps above. If you still have trouble, send the complete
output of setting and exporting your EPICS_HOST_ARCH environment
variable and running make.
Lewis
J. Lewis Muir
Software Engineer
IMCA-CAT
- error compiling base R3-14-11 gabriele marano
Re: archiving system Ralph Lange
Re: archiving system Jack
<2010>
2025
2026
Re: error compiling base R3-14-11 Martin Konrad
archiving system Dirk Martin
<2010>
2025
2026
