1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CALC expression
To: "Redman, Russell" <[email protected]>
Cc: [email protected]
Date: Wed, 29 Sep 2010 13:37:16 -0400
On 29.09.2010 13:30, Redman, Russell wrote:
Â[...]
5) Way back, around 2004 I think it was, Tim Mooney helped me with a with a customization of the postfix and calcPerform routines that allowed expressions like MAX(A,B,C), which are much more compact than MAX(A,MAX(B,C)). These never made it into base because they broke expressions like A?B, whichÂIÂnever usedÂbecause they leave unpredictable numbers of items on the stack, but which turn out to be common in some applications. If the CALC record is reworked, canÂI suggest that this issue be re-examined at the same time?
A different solution for MAX(...) is part of 3.14.10 (released Oct 2008).
Ralph
CALC expression Andrew Wagner
Re: CALC expression Andrew Johnson
Re: CALC expression Tim Mooney
Re: CALC expression Eric Norum
RE: CALC expression Redman, Russell
Prev: RE: CALC expression Redman, Russell
Next: Re: archiving system Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CALC expression Andrew Johnson
ANJ, 29 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
