1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: vxWorks 6.7 tNet0 task crashed with fage fault: help needed from vxWorks guru
To: Matthias Clausen <[email protected]>
Cc: Siegfried Rettig <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 30 Sep 2010 14:20:12 -0400
Matthias Clausen wrote:
Good idea - we got a hint from the hardware vendor that there might be a vxWorks 6.7 "SMP Perfomance Patch" which should solve 'similar' problems. - We'll check with WRS.
Strange enough that they did not mention this to us...
2) Also look for vxWorks 6 patches which could be installed.
Hello Matthias--
The "Page Fault Addr : 0x00000000" looks very suspicious. Null pointer somewhere? Strange that is is occurring in what looks to be deep within tNetTask.
I would second the suggestion to apply recommended patches for 6.7. We started putting VxWorks 6.7 into production during our summer maintenance period (~8 IOCs so far), so the longest running production IOC with this version is less then 2 months uptime. But we have not seen any such problems in testing or production. We do have all WRS recommended patches as of July 9 (from trying to debug a geiEnd driver problem for the mv5500, fixed in 6.8 by the way).
Unfortunately all of the network diagnostics do not work after a crash of the net task.
The shell will be blocked and no more diagnostics are possible.
We saw this before with 5.5 and it does make it very difficult to debug. In our case, memory corruption was occurring from another task writing beyond a malloc'd buffer, clobbering the meta data and making a mess of the free list. That task would end up suspended during either a malloc or free, so it ended up holding the semaphore protecting malloc/free. Apparently, tnetTask (at least in 5.5) does lots of malloc/free so we would find the suspended task promoted to priority 50 with tnetTask waiting on it to get the semaphore (and thus no network). The console shell would work, but a number of the show routines also use malloc. If you use any of those, the shell ends up blocking on the same semaphore and your only option is a reboot.
Does 'i' show anything promoted to a higher priority for you?
-- Steven Hartman [email protected] || 865-466-6473
RE: vxWorks 6.7 tNet0 task crashed with fage fault: help needed from vxWorks guru Jeff Hill
Re: vxWorks 6.7 tNet0 task crashed with fage fault: help needed from vxWorks guru Matthias Clausen
Prev: Re: Cross compiling EPICS for cris v10 Matthieu Bec
Next: RE: vxWorks 6.7 tNet0 task crashed with fage fault: help needed from vxWorks guru Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: vxWorks 6.7 tNet0 task crashed with fage fault: help needed from vxWorks guru Matthias Clausen
ANJ, 30 Sep 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
