a couple of times, I had the default optimize level create all kind of
weird issues, those went away lowering the opt level or disabling it
completely.
You can set that in your $(TOP)/configure/ files, consult the AppDev
guide for their names and locations: OPT_CXXFLAGS_ etc
and recompile from scratch
make clean all
Matthieu
On 09/30/10 12:04, Mark Rivers wrote:
I have never seen an error like that.
What type of system are you building for, an embedded IOC or a
workstation?
You are using asyn R4-10 which is quite old, and was tested with EPICS
3.14.8, but I don't think that is the problem. Could you be running out
of memory on the target system?
It did build the executables in the asyn test directories OK, right? So
the linker can build executables, just not your IOC executable?
-----Original Message-----
Sent: Thursday, September 30, 2010 10:29 AM
To: Mark Rivers
Cc: Florian Feldbauer; [email protected]
Subject: RE: Cross compiling EPICS for cris v10
Ok, now I was able to build synApps (Stream, Asyn, Calc, and sscan). But
still I can't build my IOC application
/usr/local/cris/lib/gcc-lib/cris-axis-linux-gnu/3.2.1/../../../../cris-a
xis-linux-gnu/bin/ld:
/usr/Epics/synApps/synApps_5_4_1/support/asyn/4-10/lib/linux-cris_v10/li
basyn.a(devAsynInt32.o):
No PLT for relocation R_CRIS_32_GOTPLT against symbol
`epicsRingBytesCreate' from .text section
final link failed: Bad value
collect2: ld returned 1 exit status
make[3]: *** [slowCtrl] Error 1
make[3]: Leaving directory
`/usr/Epics/slowCtrl/slowCtrlApp/src/O.linux-cris_v10'
make[2]: *** [install.linux-cris_v10] Error 2
make[2]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp'
make: *** [slowCtrlApp.install] Error 2
Florian
Matthieu Bec Gemini Observatory
Tel: +56 51 205785 c/o AURA, Casilla 603
Fax: +56 51 205650 La Serena, Chile
- Cross compiling EPICS for cris v10 Florian Feldbauer
- RE: Cross compiling EPICS for cris v10 Mark Rivers
- RE: Cross compiling EPICS for cris v10 Florian Feldbauer
Re: Cross compiling EPICS for cris v10 Tim Mooney
Re: vxWorks 6.7 tNet0 task crashed with fage fault: help needed from vxWorks guru Steven M. Hartman
<2010>
2025
2026
Re: Cross compiling EPICS for cris v10 Andrew Johnson
Re: Cross compiling EPICS for cris v10 Burkhard Kolb
<2010>
2025
2026
