1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Cross compiling EPICS for cris v10
Cc: tech-talk Mailing List <[email protected]>, Florian Feldbauer <[email protected]>
Date: Thu, 30 Sep 2010 22:36:00 +0200
Well Mark,
Peter Zumbruch posted the same error some time ago on 28th of June (subject: No PLT for relocation)
At that time nobody responded ...
We also still have no solution, it seems to be a linker problem with the cris-gnu stuff.
Burkhard
Am 30.09.2010 um 18:04 schrieb Mark Rivers:
> I have never seen an error like that.
> What type of system are you building for, an embedded IOC or a
> workstation?
> You are using asyn R4-10 which is quite old, and was tested with EPICS
> 3.14.8, but I don't think that is the problem.  Could you be running out
> of memory on the target system?
> It did build the executables in the asyn test directories OK, right?  So
> the linker can build executables, just not your IOC executable?
> Mark
> -----Original Message-----
> From: Florian Feldbauer [mailto:[email protected]]
> Sent: Thursday, September 30, 2010 10:29 AM
> To: Mark Rivers
> Cc: Florian Feldbauer; [email protected]
> Subject: RE: Cross compiling EPICS for cris v10
> Ok, now I was able to build synApps (Stream, Asyn, Calc, and sscan). But
> still I can't build my IOC application
> /usr/local/cris/lib/gcc-lib/cris-axis-linux-gnu/3.2.1/../../../../cris-a
> xis-linux-gnu/bin/ld:
> /usr/Epics/synApps/synApps_5_4_1/support/asyn/4-10/lib/linux-cris_v10/li
> basyn.a(devAsynInt32.o):
> No PLT for relocation R_CRIS_32_GOTPLT against symbol
> `epicsRingBytesCreate' from .text section
> final link failed: Bad value
> collect2: ld returned 1 exit status
> make[3]: *** [slowCtrl] Error 1
> make[3]: Leaving directory
> `/usr/Epics/slowCtrl/slowCtrlApp/src/O.linux-cris_v10'
> make[2]: *** [install.linux-cris_v10] Error 2
> make[2]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp/src'
> make[1]: *** [src.install] Error 2
> make[1]: Leaving directory `/usr/Epics/slowCtrl/slowCtrlApp'
> make: *** [slowCtrlApp.install] Error 2
> Florian
Dr. Burkhard Kolb
Pleikartsförster Str. 38
69124 Heidelberg
Germany
E-Mail: [email protected]
Tel: +49 6221 718640 / Fax: +49 6221 718641
Re: Cross compiling EPICS for cris v10 Dirk Zimoch
Cross compiling EPICS for cris v10 Florian Feldbauer
RE: Cross compiling EPICS for cris v10 Mark Rivers
RE: Cross compiling EPICS for cris v10 Florian Feldbauer
Prev: RE: vxWorks 6.7 tNet0 task crashed with fage fault: help needed from vxWorks guru Jeff Hill
Next: Channel Archiver overlapping blocks james.rowland
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Cross compiling EPICS for cris v10 Matthieu Bec
Next: Re: Cross compiling EPICS for cris v10 Dirk Zimoch
ANJ, 01 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
