1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MOXA ARM computer and streamDevice
To: "Martin Konrad" <[email protected]>, "EPICS tech-talk" <[email protected]>
Date: Fri, 1 Oct 2010 14:48:20 -0400
Hi Martin,
I played with Moxa DA662(2 more Ethernet ports than DA661) for a while and made it work with base(3.14.10) + asyn(4.10) + StreamDevice(2.4). The cross compiler(linux-xscale_be) source code is from Moxa, but we rebuilt it. The whole cross compiling process takes some efforts. I can send you the static cross-complied executable(base, asyn and stream all included) if you want.
My application is to monitor 1-wire temperature sensors (~20K) for NSLS-2. We need 90 Moxa DA662, that's a big number. For better system maintenance and software development, I'm going to abandon Moxa DA-662 and changing to use 5 powerful and stable servers(multiple cpu cores) to handle all 1-wire stuff. Another reason I don't like Moxa DA66x is that the Linux/Debian inside Moxa has limited tools/commands so that it's painful to use.
Hope you make a good decision.
Yong
>-----Original Message-----
>From: [email protected] [mailto:tech-talk-
>[email protected]] On Behalf Of Martin Konrad
>Sent: Friday, October 01, 2010 2:20 PM
>To: EPICS tech-talk
>Subject: MOXA ARM computer and streamDevice
>Hi all,
>we are thinking about running IOCs for RS232 devices on ARM based data
>aquisition computers from MOXA (DA-661):
>http://store.moxa.com/j2bc_ext/doc/prodbase/M20090309140/DA-660-
>I_Series.pdf
>Can someone who already works with similar devices tell us if this
>should work
>with base + asyn + streamDevice? What tool-chain did you use for cross
>compiling? Did it work smoothly? What are your experiences regarding
>time
>effort for cross compiling? - Of course setting up a standard Linux PC
>together
>with a simple device server does the same job. But fewer devices/PCs
>means
>less trouble...
>best regards
>Martin
>Dipl. Phys. Martin Konrad
>Technische Universität Darmstadt
>Institut für Kernphysik
>Schlossgartenstr. 9
>64289 Darmstadt
>Tel: +49-6151-16-5121
>Fax: +49-6151-16-4321
Re: MOXA ARM computer and streamDevice Dirk Zimoch
MOXA ARM computer and streamDevice Martin Konrad
Prev: RE: Cross compiling EPICS for cris v10 Florian Feldbauer
Next: Contact at Sandia Akridge, Charles S. (MSFC-ES52)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: MOXA ARM computer and streamDevice Martin Konrad
Next: Re: MOXA ARM computer and streamDevice Dirk Zimoch
ANJ, 04 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
