1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MOXA ARM computer and streamDevice
To: "Hu, Yong" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 04 Oct 2010 14:56:47 +0200
Hello Yong,
I am also interested in this issue.
What is the problem in the cross compiling process?
Can I use NFS on the DA66*?
Are there other alternatives (i.e. 19" computers with many RS232/485 ports)? So far I used a solution with an additional PC providing remote tty devices. But I like the idea of running EPICS directly on the machine with the ttys.
Dirk
Hu, Yong schrieb:
Hi Martin,
I played with Moxa DA662(2 more Ethernet ports than DA661) for a while and made it work with base(3.14.10) + asyn(4.10) + StreamDevice(2.4). The cross compiler(linux-xscale_be) source code is from Moxa, but we rebuilt it. The whole cross compiling process takes some efforts. I can send you the static cross-complied executable(base, asyn and stream all included) if you want.
My application is to monitor 1-wire temperature sensors (~20K) for NSLS-2. We need 90 Moxa DA662, that's a big number. For better system maintenance and software development, I'm going to abandon Moxa DA-662 and changing to use 5 powerful and stable servers(multiple cpu cores) to handle all 1-wire stuff. Another reason I don't like Moxa DA66x is that the Linux/Debian inside Moxa has limited tools/commands so that it's painful to use.
Hope you make a good decision.
Yong
-----Original Message-----
[email protected]] On Behalf Of Martin Konrad
Sent: Friday, October 01, 2010 2:20 PM
To: EPICS tech-talk
Subject: MOXA ARM computer and streamDevice
Hi all,
we are thinking about running IOCs for RS232 devices on ARM based data
aquisition computers from MOXA (DA-661):
http://store.moxa.com/j2bc_ext/doc/prodbase/M20090309140/DA-660-
I_Series.pdf
Can someone who already works with similar devices tell us if this
should work
with base + asyn + streamDevice? What tool-chain did you use for cross
compiling? Did it work smoothly? What are your experiences regarding
time
effort for cross compiling? - Of course setting up a standard Linux PC
together
with a simple device server does the same job. But fewer devices/PCs
means
less trouble...
best regards
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel: +49-6151-16-5121
Fax: +49-6151-16-4321
RE: MOXA ARM computer and streamDevice Hu, Yong
MOXA ARM computer and streamDevice Martin Konrad
Prev: Re: seq pvPut to a waveform Ben Franksen
Next: RE: MOXA ARM computer and streamDevice Hu, Yong
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MOXA ARM computer and streamDevice Hu, Yong
ANJ, 04 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
