On Samstag, 2. Oktober 2010, Dayle Kotturi wrote:
> I'd be grateful for code snippets showing how to put a waveform of
> values to a PV. I am able to successfully pvPut other data types, but
> just not waveforms. I've tried to match the sytax of caput -a where
> the first arg is NELM (or NORD) and then the array is appended after
> that.
No, this is just caput command line syntax. Just pvPut the array of
values.
> I've also tried just puttting the array of NELM values.
> Neither worked.
It should. But see below for a possible reason why your program does not
work.
> No error messages on the console with +d option set.
> Recompiling seq-R2-0-11 with DEBUG defined caused a segmentation
> fault. I didn't investigate the reason for that.
Not necessary, I already fixed this a while ago in the development
version. Seems nobody tried to compile with DEBUG for a long time...
> Versions: epics3.14.8.2 and seq-R2-0-11
> Platform: linux-x86
> Details: I have a waveform of 21 shorts that I want to put to a PV of
> FTVL USHORT with NELM 21.
> [cdlx08] /afs/slac/g/lcls/tools/script>caget KLYS:LI20:95:RULE0
> KLYS:LI20:95:RULE0 21 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0
> On the (soft) ioc:
> epics> dbpr("KLYS:LI20:95:RULE0",4)
> ACKS: NO_ALARM ACKT: YES ASG: ASP:
> 0x00000000 BKPT: 0x00 BPTR: 0x483eef09 BUSY: 0
> DESC: Rule DISA: 0 DISP: 0 DISS: NO_ALARM
> DISV: 1 DPVT: 0x00000000 DSET: 0xfc578000 DTYP: Soft Channel
> EGU: tick EVNT: 0 FLNK:CONSTANT 0 FTVL: USHORT
> HOPR: 0 INP:CONSTANT LCNT: 0 LOPR: 0
> LSET: 0xc06cf309 MLIS: 0x98adf80988a9f80902000000 MLOK:
> 0x303eef09
> NAME: KLYS:LI20:95:RULE0 NELM: 21 NORD: 21
> NSEV: NO_ALARM NSTA: NO_ALARM PACT: 0 PHAS: 0
> PINI: YES PPN: 0x00000000 PPNR: 0x00000000 PREC: 0
> PRIO: LOW PROC: 0 PUTF: 0 RARM: 0
> RDES: 0x20a6e009 RPRO: 0 RSET: 0x203ed800 SCAN:
> Passive SDIS:CONSTANT SEVR: NO_ALARM SIML:CONSTANT
> SIMM: NO SIMS: NO_ALARM SIOL:CONSTANT SPVT: 0x00000000
> STAT: NO_ALARM TIME: 0x0cd6072760513f19 TPRO: 0
> TSE: 0 TSEL:CONSTANT UDF: 0 VAL: 0x00000000
> at top before start of state set:
> option -a; /* sync op. wait for pvGet/pvPut to complete */
> option -c; /* no wait for db connections */
> option +d; /* Turn on runtime debug messages */
> option +w; /* Display SNC warnings */
> #define PDU_RULE_PUT_WF_SIZE 22 /* includes 1 for the NELM */
> /* Tempory variable re-used to hold the trigger rule copied from an
> updated global rule and assigned to an RTEMS IOC trigger rule
> that uses it */ short myTriggerRule[PDU_RULE_PUT_WF_SIZE];
> assign myTriggerRule to ""; /* MUST do this to get this var into DB
> Block per Kuhkee Kim 2010/09/30 */
> /* Inside a state */
> pvAssign(myTriggerRule,"KLYS:LI20:95:RULE0");
> pvMonitor(myTriggerRule);
At this point, i.e. before calling pvPut, you must first ensure that
myTriggerRule has connected to the assigned PV: connecting to a PV is
an asynchronous operation. This can be done by jumping to an additional
state:
state wait_connect_myTriggerRule {
when (pvConnected(myTriggerRule)) {
pvPut(myTriggerRule);
... etc. ...
> /* Update the definition of the trigger rule to match
> the global rule it is assigned to */
> pvFlush();
> printf("sncpdu: contents of SNL var now put into EPICS
> PV\n");
> sprintf(pvNORD, "%s.NORD",triggerRuleStrings[nn]);
> pvAssign(myTriggerRuleNORD,pvNORD);
It is not necessary nor makes sense to write to NORD, as this field is
updated by the record support put_array_info method which is called
whenever VAL gets written to (e.g. via CA).
Cheers
Ben
- seq pvPut to a waveform Dayle Kotturi
Re: MOXA ARM computer and streamDevice Dirk Zimoch
<2010>
2025
2026
EPICS Collaboration Meeting - arrival instructions Dalesio, Leo
<2010>
2025
2026
