1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VDCT PostScript problem
To: <[email protected]>
Date: Fri, 8 Oct 2010 14:39:34 -0400
Hi Eric,
I don't normally use this feature. Quick check here gives me the same problem. One work around: select 'print preview', click the print button there, use something like cups-pdf (linux) that worked for me.
Might not be very helpful if you bulk process a bunch of schematics from command line (if that option exists).
Matthieu
On 10/08/10 14:12, Eric Norum wrote:
A while back I posted a message about my inability to convert VDCT drawings to PostScript:
VDCT -- 2.6.1274 on OS X and on LInux
When I try to export as PostScript I get the following error:
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
	at java.lang.AbstractStringBuilder.insert(AbstractStringBuilder.java:979)
	at java.lang.StringBuffer.insert(StringBuffer.java:446)
	at com.cosylab.vdct.VisualDCT.printGrid(Unknown Source)
	at com.cosylab.vdct.VisualDCT$1MyOwnPostScriptExportingThread.run(Unknown Source)
Is there some setting that I've missed? Some workaround that will let this proceed?
I received no responses thus leading me to believe that:
A) VDCT is dead.
or
B) No one else has a problem with this conversion.
or
C) No one else needs to get PostScript images for inclusion in other documentation or archival in a document control system.
So -- which of the above statements is true?
Hopefully,
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
VDCT PostScript problem Eric Norum
Re: VDCT PostScript problem Eric Norum
Prev: Re: VDCT PostScript problem Pete R. Jemian
Next: Re: VDCT PostScript problem Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VDCT PostScript problem Eric Norum
Next: seq pvPut to a waveform Dayle Kotturi
ANJ, 08 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
