1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VDCT PostScript problem
To: "Nicholas P. DiMonte" <[email protected]>
Cc: "[email protected] tech-talk" <[email protected]>
Date: Fri, 8 Oct 2010 11:43:37 -0700
Interesting.
I am able to print the drawings (at least on the Toshiba e-STUDIO205 printer next door).
The explicit conversion to PostScript (via either the 'Export to PostScript' menu item or the 'Print as PostScript' menu item) that fails.
On Oct 8, 2010, at 11:36 AM, Nicholas P. DiMonte wrote:
Never tried it before, but on my Window machine I get an error saying "PostScript not supported on selected printer" even on a post-script printer.
I have never been successful printing from VDCT.
Nick D.
On 10/8/2010 1:12 PM, Eric Norum wrote:
A while back I posted a message about my inability to convert VDCT drawings to PostScript:
VDCT -- 2.6.1274 on OS X and on LInux
When I try to export as PostScript I get the following error:
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
	at java.lang.AbstractStringBuilder.insert(AbstractStringBuilder.java:979)
	at java.lang.StringBuffer.insert(StringBuffer.java:446)
	at com.cosylab.vdct.VisualDCT.printGrid(Unknown Source)
	at com.cosylab.vdct.VisualDCT$1MyOwnPostScriptExportingThread.run(Unknown Source)
Is there some setting that I've missed?   Some workaround that will let this proceed?
I received no responses thus leading me to believe that:
A) VDCT is dead.
or
B) No one else has a problem with this conversion.
or
C) No one else needs to get PostScript images for inclusion in other documentation or archival in a document control system.
So -- which of the above statements is true?
Hopefully,
Eric Norum
[email protected]
VDCT PostScript problem Eric Norum
Re: VDCT PostScript problem Eric Norum
Re: VDCT PostScript problem Nicholas P. DiMonte
Prev: Re: VDCT PostScript problem Matthieu Bec
Next: Base R3.14.12-pre1 ready for testing Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VDCT PostScript problem Pete R. Jemian
Next: Re: VDCT PostScript problem Matthieu Bec
ANJ, 08 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
