1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11
To: Jerome HOSSELET <[email protected]>
Cc: [email protected]
Date: Mon, 11 Oct 2010 14:17:00 -0500
Hello Jerome,
I had to make a change to the,
<motor>/motorApp/MotorSrc/motor.h
file in order to successfully compile it for a VxWorks 6.x
target architecture.  I am surprised that you are not getting
a compiler error.
I planned on releasing a minor version update (R6.5.2)
that includes the above change to the motor.h file,
but I have made the motor.h file change available here.
So let us see if that fixes the problems you are experiencing
before I make a new motor record release.
Ron
On 10/11/2010 10:08 AM, Jerome HOSSELET wrote:
Hi all,
I have some troubles with a motor driver v 6.5.1 and EPICS base 3.14.11 and VxWorks 6.8
VxWorks 6.8 : install ok
Base EPICS 3.14.11 : compilation ok
Support motor 6.5.1: compilation ok
I use a MAXv-4000 with a servo configuration (PSM configuration).
When i use a VxWorks 6.7 and motor 6.4.4 and base 3.14.8.2 => all it's ok
but when i move in last release all package it doesn't works.
The home status : ATHM always = 0
During the motion a message appear Motion = "Move"  &&  "Communication error"
When i check my analogic output for motor 1 (commande analogic to the servo)
I probe always 10 V.
It's not normal ......
Ron or other can i help me ?
Jerome HOSSELET
[email protected]
Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Daron Chabot
No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Jerome HOSSELET
Prev: Timeout errors with ASYN Modbus Driver 2.0 David Dudley
Next: RE: Timeout errors with ASYN Modbus Driver 2.0 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Jerome HOSSELET
Next: Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Daron Chabot
ANJ, 11 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
