Hi Jerome,
On Monday 11 October 2010 10:08:02 Jerome HOSSELET wrote:
> I have some troubles with a motor driver v 6.5.1 and EPICS base 3.14.11 and
> VxWorks 6.8
> VxWorks 6.8 : install ok
> Base EPICS 3.14.11 : compilation ok
> Support motor 6.5.1: compilation ok
We found a problem with our munching of vxWorks binaries when used with the
later vxWorks 6.x versions that use the GNU C++ 4.x compilers, and I wonder if
this might be related to what you're experiencing since I believe the Motor
record has C++ code in it. There is a patch on the Known Problems page for
R3.14.11 which you should try in case it fixes the issue (and you should
probably look at the other patches there too in case any of them apply to your
usage):
http://www.aps.anl.gov/epics/base/R3-14/11-docs/KnownProblems.html
HTH,
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Jerome HOSSELET
Re: gateway putlog Andrew Johnson
Re: gateway putlog Ben Franksen
<2010>
2025
2026
Re: No HomeStatus and No Motion with OMS MAXv : Motor 6.5.1 / VxWorks 6.8 / base 3.14.11 Daron Chabot
Timeout errors with ASYN Modbus Driver 2.0 David Dudley
<2010>
2025
2026
