1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Calling an iocsh "sub-script"
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 13 Oct 2010 12:32:21 -0500
On 10/13/10 10:08 AM, Josh Stein wrote:
> I would like to point out one warning with these embedded scripts -
> there is a very real possibility of breaking some higher level tools
> which rely on 'crawling' the startup command files for information. This
> very issue has just cropped up here at APS when the st.cmd structure of
> a number of our production IOCs was cleaned up during a recent 3.14
> upgrade.
> In essence, some of our crawlers were unable to parse relevant tags
> since they failed to show up in the st.cmd file itself as those tags
> were moved to one or more of the 'sub-scripts'.
> For now, the crawlers at APS are being re-written to follow the
> indirection. This is yet another example of how fragile the system
> structure can grow over time; the hooks into various parts actually
> increase the risk of things breaking as time progresses.
I don't think there should be anything wrong w/ using features supported
in the EPICS IOC shell.  The problem is the crawlers.  The crawlers were
fragile; they made assumptions about the st.cmd file.  To solve a
problem relatively quickly, sometimes this is OK, but then in a case
like this, one has to go back and fix it.  It could still be the right
decision.  Maybe one just needs some test cases to ensure the crawler
works for the cases needed or some checking script to ensure the crawler
is still working.
A robust crawler would actually be able to parse the IOC shell input,
constructing an abstract syntax tree or converting the input into some
other useful form, dealing w/ variable substitutions, etc., so the task
of the crawler could be implemented correctly.  This is obviously much
more work.
Lewis
Re: Calling an iocsh "sub-script" Ben Franksen
Calling an iocsh "sub-script" Angus Gratton
RE: Calling an iocsh "sub-script" Mark Rivers
Re: Calling an iocsh "sub-script" Josh Stein
Prev: Re: EPICS CA problems J. Lewis Muir
Next: Re: Calling an iocsh "sub-script" J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Calling an iocsh "sub-script" Stephen Lewis
Next: Re: Calling an iocsh "sub-script" Ben Franksen
ANJ, 14 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
