Subject: |
RE: slow caput from R3.14.11 client to R3.14.9 IOC |
"Jeff Hill" <[email protected]> |
To: |
"'tech-talk'" <[email protected]> |
Date: |
Thu, 14 Oct 2010 16:20:19 -0600 |
Hi Mark,
I ran some quick tests of R3.14.11 on my pc.
I see a maximum throughput closer to a million puts
per second when doing routine tests of the ca client library
against the ca example server (excas), but this is not connecting
and disconnecting the channel with each put. I can also
connect around 50000 channels per second. This is probably
with a debug (no optimization) build.
It takes about 8 seconds to run a script that does 100 caput
command line requests against the example server on my workstation.
Jeff
______________________________________________________
Jeffrey O. Hill Email [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107
Message content: TSPA
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Mark Boots
> Sent: Thursday, October 14, 2010 2:20 PM
> To: [email protected]
> Subject: slow caput from R3.14.11 client to R3.14.9 IOC
> Hi all,
> We've noticed at the CLS that channel access puts (caput) from a
> default R3.14.11 build (linux-x86) to a 14.9 IOC are very slow. As a
> test, we ran a shell script with ~100 caput (command line) calls; it
> took ~ 24 seconds to complete using the 14.11 version of caput, and
> only 6s for the 14.9 version.
> Asynchronous caputs (using the channel access library, instead of the
> command line) seem to be even slower -- sometimes taking over a minute
> for the IOC to respond to all 100 puts.
> We're still debugging to see if this is a peculiarity of the IOC. I'm
> just wondering if anyone has seen similar issues involving channel
> access between different EPICS versions? Any suggestions for tools or
> methods to help diagnose the problem?
> Best regards,
> -Mark
> Mark Boots
> Dept. of Physics and Engineering Physics
> University of Saskatchewan
> Rm 202 Physics Building
> 116 Science Place,
> Saskatoon SK S7N 5E2
> Canada
> (306) 261-4162
- Re: slow caput from R3.14.11 client to R3.14.9 IOC Andrew Johnson
Aerotech Ensemble home search problem Ron Sluiter
Re: problem with tpmac-3-7 (loading IOC munch file results in undefined symbol error) Sergey Stepanov
<2010>
2025
2026
slow caput from R3.14.11 client to R3.14.9 IOC Mark Boots
<2010>
2025
2026
