1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Aerotech Ensemble home search problem
To: EPICS <[email protected]>
Date: Thu, 14 Oct 2010 16:41:37 -0500
I recently discovered a problem with performing a home search from the EPICS motor record when using an Aerotech Ensemble motor controller.  The problem is that the EPICS Ensemble driver uses Aerotech's ASCII communication protocol and that protocol blocks all communication on ASCII communication ports during a home search.  Consequently, once a home search is started from EPICS, it is unable to stop it.
Aerotech is aware of the problem and have plans to fix this, but a release date has not been set yet.
I have made a motor record minor bug fix release (6.5.2) available here with the home search function commented out of the Ensemble driver.  I advise Ensemble users to upgrade to this version.  Users that need to perform a home search should do it from Aerotech's IDE software, which can abort a home search.
Ron
Prev: RE: MOXA ARM computer and streamDevice Mark Boots
Next: RE: slow caput from R3.14.11 client to R3.14.9 IOC Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: slow caput from R3.14.11 client to R3.14.9 IOC Andrew Johnson
Next: Re: problem with tpmac-3-7 (loading IOC munch file results in undefined symbol error) Sergey Stepanov
ANJ, 15 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
