1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: MOXA ARM computer and streamDevice
To: Dirk Zimoch <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 14 Oct 2010 14:55:08 -0600
Hi Dirk,
At the CLS they're using the MOXA UC-7408 (http://www.moxa.com/product/UC-7408.htm) all over the place for integrating RS-232 devices.   It's not powerful, but it's got 8 serial ports and comes running Linux.  NFS mounted filesystems work fine with it.
I've used them with EPICS + asyn + StreamDevice on four different projects.  The cross-compile is pretty smooth, using the mxscaleb compiler toolchain distributed by MOXA (http://www.moxa.com/drivers/UC/toolchain_mxscaleb/mxscaleb-3.3.2-9.i386.zip -- Linux 2.4 only?).
Here's my cross-compile configuration file: base/configure/os/CONFIG.Common.linux-armb  (*)
Good luck!
-Mark
(*) was written by Glen Wright at the CLS, for EPICS 14.9.  I modified it to fix a bug in the omission of the -D_ARM_NWFP_ flag in ARCH_DEP_CPPFLAGS, which was corrupting channel access floating point data, due to the reversed word order it uses to store doubles.
Attachment: CONFIG.Common.linux-armb
Description: Binary data
Prev: slow caput from R3.14.11 client to R3.14.9 IOC Mark Boots
Next: Aerotech Ensemble home search problem Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: MOXA ARM computer and streamDevice Xu, Huijuan
Next: Contact at Sandia Akridge, Charles S. (MSFC-ES52)
ANJ, 14 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
