What architecture are you running on? Linux? vxWorks? If it is Linux you can just enable core dumps
limit core 100000
Then when it crashes run gdb on the application and the core dump and see what where it crashed. Or you can run the application directly with gdb.
Sent: Thu 10/14/2010 8:48 PM
To: [email protected]
Subject: Problem in registerRecordDeviceDriver
I'm using PI C-863 Mercury motor controller to control PI M-126 stage under EPICS. I currently use the 6.5.1 version for MotorSrc, PiSrc, and I
compiled successfully under EPICS version 3.14.11, with supported of packages sncseq-2.0.12, asyn4-13-1, ipac-2.10, and
calc-2-8. However we encountered an segmentation fault error in executing st.cmd when trying to run command of xxx_registerRecordDeviceDriver pdbbase.
could anybody give me a hint on the problem!
Thanks
Xinyu Ao
SSRF
- Re: Problem in registerRecordDeviceDriver Ralph Lange
- Re: Problem in registerRecordDeviceDriver Xinyu Ao
- Problem in registerRecordDeviceDriver Xinyu Ao
CSS XY Graph show/hide traces PaweÅ PrÄdki
<2010>
2025
2026
<2010>
2025
2026
