1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem in registerRecordDeviceDriver
To: Mark Rivers <[email protected]>, [email protected]
Date: Sat, 16 Oct 2010 06:35:19 +0800
Hi, Mark,
     Thanks for your kind advice, the architecture is linux.  I didn't enable core dump in my machine. I will set it up, and try to figure out the reason.
       Best regards
        Xinyu
On Fri, Oct 15, 2010 at 7:50 PM, Mark Rivers <[email protected]> wrote:
What architecture are you running on?  Linux? vxWorks?  If it is Linux you can just enable core dumps
limit core 100000
Then when it crashes run gdb on the application and the core dump and see what where it crashed.  Or you can run the application directly with gdb.
Sent: Thu 10/14/2010 8:48 PM
To: [email protected]
Subject: Problem in registerRecordDeviceDriver
    I'm using PI C-863 Mercury motor controller to control PI M-126 stage under EPICS. I currently use the 6.5.1 version for MotorSrc, PiSrc, and I
compiled successfully under EPICS version 3.14.11, with supported of packages sncseq-2.0.12, asyn4-13-1, ipac-2.10, and
calc-2-8.  However we encountered an segmentation fault error in executing st.cmd when trying to run command of xxx_registerRecordDeviceDriver pdbbase.
   could anybody give me a hint on the problem!
  Thanks
  Xinyu Ao
 SSRF
Problem in registerRecordDeviceDriver Xinyu Ao
RE: Problem in registerRecordDeviceDriver Mark Rivers
Prev: Re: Problem in registerRecordDeviceDriver Xinyu Ao
Next: RE: CSS XY Graph show/hide traces Chen, Xihui
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: IDE (was: Problem in registerRecordDeviceDriver) Ralph Lange
Next: Re: Problem in registerRecordDeviceDriver Andrew Johnson
ANJ, 16 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
