Hi, Dear Andrew,
The hardware is an laptop with Intel X86, the OS is Cent OS 5, I think there were some warning messages in the building process. However, it may be not the reason of the problem, please refer my previous mail, I solved it by rebuilding the application. It is kind of weird.
Also, I didn't know how to examine the error log for epics, could you tell me how to do it. I think maybe, I could get better idea of the problem when I examined the log.
Best Regards
Xinyu
On Fri, Oct 15, 2010 at 9:59 PM, Andrew Johnson <[email protected]> wrote:
On Thursday 14 October 2010 20:48:15 Xinyu Ao wrote:
> I’m using PI C-863 Mercury motor controller to control PI M-126 stage
> under EPICS. I currently use the 6.5.1 version for MotorSrc, PiSrc, and I
> compiled successfully under EPICS version 3.14.11, with supported of
> packages sncseq-2.0.12, asyn4-13-1, ipac-2.10, and
> calc-2-8. However we encountered an segmentation fault error in executing
> st.cmd when trying to run command of xxx_registerRecordDeviceDriver
> pdbbase.
What hardware and OS is your IOC running on? Were there any warning or error
messages displayed when you built the IOC binary? A seg-fault that early
would probably have resulted in one or more warnings, and if so you should
concentrate on resolving them properly (if you need help with that, post the
output from the make process that shows those messages).
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- Re: Problem in registerRecordDeviceDriver Andrew Johnson
- Problem in registerRecordDeviceDriver Xinyu Ao
Re: Problem in registerRecordDeviceDriver Xinyu Ao
<2010>
2025
2026
<2010>
2025
2026
ANJ, 18 Oct 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
