Hi, Dear Mark and Andrew,
Thanks for your quick response! Sorry for my late response! The architecture is linux-x86, the error is kind of strange, I examined the code, it turned out the record type of waveform, motor, and scalcout etc, could not be found by the IOC modules. I found it to be of non-sense, for the transform record shared the same modules with scalcout could be found by the modules. However, I fixed the problem by rebuild the application for scratch again. I don't know the reason it got fixed.
And Ron, thanks for your kind remind.
Best Regards to you
Xinyu @ ssrf
On Fri, Oct 15, 2010 at 11:41 PM, Ron Sluiter <[email protected]> wrote:
Hello Xinyu,
May I make a suggestion?
When you ask for help on tech-talk
it is considered "good form" to
respond with a short message
indicating your problem is fixed
and possibly, how it was fixed.
This way other tech-talk users will
stop trying to help you fix the problem
and they may learn from your experience.
Ron
On 10/14/2010 8:48 PM, Xinyu Ao wrote:
I’m using PI C-863 Mercury motor
controller to control
PI M-126 stage under EPICS. I currently use the
6.5.1 version for MotorSrc, PiSrc, and I
compiled successfully under EPICS version 3.14.11, with supported
of packages sncseq-2.0.12, asyn4-13-1, ipac-2.10, and
calc-2-8. However we encountered an segmentation fault error in
executing st.cmd when trying to run command of
xxx_registerRecordDeviceDriver pdbbase.
could anybody give me a hint on the problem!
Thanks
Xinyu Ao
SSRF
- Problem in registerRecordDeviceDriver Xinyu Ao
Eurotherm Temperature Controller Support Chris Whiting
Re: Problem in registerRecordDeviceDriver Xinyu Ao
<2010>
2025
2026
Re: Problem in registerRecordDeviceDriver Andrew Johnson
CSS XY Graph show/hide traces PaweÅ PrÄdki
<2010>
2025
2026
ANJ, 18 Oct 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
