1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Client failed to connect to local server on VxWorks and Pharlap
To: [email protected]
Date: Fri, 22 Oct 2010 12:35:04 +0800
Hi All,
I wrote an EPICS Server and an EPICS Client based on EPICS Base. They work well on Windows platform. Now I'm porting them to VxWorks and Pharlap.
During porting, I found the issue that, if the client and server are on a single host (no matter VxWorks or Pharlap), the connection couldn't be established. Please refer to the table below.
Senario Result
Server on Windows, Client on VxWorks/Pharlap Function well.
Server on VxWorks/Pharlap, Client on Windows Function well.
Server on VxWorks, Client on Pharlap Function well.
Server on Pharlap, Client on VxWorks Function well.
Both on Windows Function well.
Both on VxWorks Cannot connect.
Both on Pharlap Cannot connect.
At the time the issue happens, I can create a client on a different platform to successfully connect to/communicate with the issuing server, I can also point the issuing client to connect to/communicate with another server on a different platform.
Do you have any clue what the issue might be?
Please let me know.
Thanks a lot in advance.
Lorna Zhang
National Instruments Shanghai
Tel: 86-21-50509810-3230
Re: Client failed to connect to local server on VxWorks and Pharlap Andrew Johnson
RE: Client failed to connect to local server on VxWorks and Pharlap Jeff Hill
Prev: Re: MEDM btn3 mouse/X11 problems on GNOME x64 (Ubuntu 10.04) Angus Gratton
Next: Re: Manipulating time in records Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Client failed to connect to local server on VxWorks and Pharlap Andrew Johnson
ANJ, 22 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
