Ø Do you have any clue
what the issue might be?
Which server is in use?
o portable server library,
standalone from an IOC (PCAS)
o original server,
embedded in an IOC (rsrv)
The PCAS is more flexible
in its configuration for which network interfaces it will receive connection request
from (details are in the ca reference manual), but the rsrv
server has a fixed configuration always receiving connection requests from all
interfaces.
Also, whether a search broadcast
sent out by clients over one of the local network interfaces will be seen by servers
on the local host or not is part of the routing/loopback policy for the local os.
Furthermore, the ca
client library typically sends search messages to the broadcast addresses of each
LAN that is attached by default, but this can be changed with configuration
(see the ca reference manual). By default, the client library builds its search
address list by interrogating the network interfaces (see the code in libCom/osi/osd/default/osdNetIntf.c).
Jeff
______________________________________________________
Jeffrey O. Hill
Email [email protected]
LANL MS
H820
Voice 505 665 1831
Los Alamos NM 87545 USA
FAX 505 665 5107
Message
content: TSPA
Hi All,
I wrote an
EPICS Server and an EPICS Client based on EPICS Base. They work well on Windows
platform. Now I'm porting them to VxWorks and Pharlap.
During porting,
I found the issue that, if the client and server are on a single host (no
matter VxWorks or Pharlap), the connection couldn't be established. Please
refer to the table below.
Senario
Result
Server
on Windows, Client on VxWorks/Pharlap
Function
well.
Server
on VxWorks/Pharlap, Client on Windows
Function
well.
Server
on VxWorks, Client on Pharlap
Function
well.
Server
on Pharlap, Client on VxWorks
Function
well.
Both
on Windows
Function
well.
Both
on VxWorks
Cannot
connect.
Both
on Pharlap
Cannot
connect.
At the time the
issue happens, I can create a client on a different platform to successfully
connect to/communicate with the issuing server, I can also point the issuing
client to connect to/communicate with another server on a different platform.
Do you have any
clue what the issue might be?
Please let me
know.
Thanks a lot in
advance.
Lorna Zhang
National Instruments Shanghai
Tel: 86-21-50509810-3230
