1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS on ARM (continued)
To: Rod Nussbaumer <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 25 Oct 2010 13:05:38 -0700
Rod,
I am basically trying to compile EPICS for the TS7370 (arm based arch).
How I achieve this is not important to me.
I looked at the TS cross toolchain.
I understand I am supposed to change my makefiles following
> CROSS = /opt/crosstool/gcc-3.3.4-glibc-2.3.2/bin/arm-linux-
> CC = $(CROSS)gcc
but how do I do that in EPICS?
I am not even sure how to correctly setup a target architecture...
export T_A=linux-arm; make
or even make T_A=linux-arm
seem to work.
My target EPICS_HOST_ARCH is linux-armv4l
My host is linux 64 bit.
It seems I need to create the files
CONFIG.linux-x86_64.armv4tl
CONFIG_SITE.linux-x86.linux-armv4tl
CONFIG.Common.linux-armv4tl
I copied ../configure/os/CONFIG...linux-arm... files to compile
But I run into several issues...
Is there any resource for cross compiling on EPICS?
Any other info on how you achieve to run epics on a TS7370 is welcome.
On 08:57 Mon 25 Oct     , Rod Nussbaumer wrote:
> I have also been able to cross compile EPICS and other applications
> using the Technologics Systems cross toolchain, but am not using that
> for production work.
Emmanuel
Re: EPICS on ARM (continued) emmanuel_mayssat
Re: EPICS on ARM (continued) Dirk Zimoch
RE: Thread model for EPICS on ARM CPU michael.abbott
Re: Thread model for EPICS on ARM CPU Rod Nussbaumer
Prev: RE: EPICS CA problems Mark Rivers
Next: Re: EPICS on ARM (continued) emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Cross Compiling Linux for Embedded Systems Michael Abbott
ANJ, 26 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
