1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Some Channel Access Questions
To: EPICS Techtalk <[email protected]>
Date: Tue, 26 Oct 2010 22:17:36 +0200
I am again hacking on the sequencer internals and thereby came to ask
myself how CA handles these cases:
- multiple ca_put_callback calls on the same channel
- multiple ca_get_callback calls on the same channel
- multiple (blocking) ca_get calls on the same channel
- a mixture of any of the above
I assume exactly one channel here, which is possibly accessed from
multiple threads.
The only unproblematic case is the simple ca_put, as it is fire and
forget; for ca_monitor I happen to know that multiple subscriptions are
fine and each subscription get its own callback on each event. Do the
other calls behave similarly, i.e. if I fire two ca_get_callback on the
same channel in a row, do I get two callbacks, too? Are there any
combinations which will fail ("sorry, pv is active")? I remember
reading some time ago that only one *db*_put_callback can be active at
a time on a record (on the IOC), so will interleaving two
ca_put_callbacks also fail? What if I interleave a synchronous ca_get
(i.e. I wait for completion using ca_pend or somesuch) with a ca_get or
ca_get_callback issued by another thread?
Cheers (head smoking)
Ben
"Never confuse what is natural with what is habitual."
                                   -- attributed to Mahatma Gandhi
RE: Some Channel Access Questions Jeff Hill
Re: Some Channel Access Questions Andrew Johnson
Prev: RE: EPICS CA problems Mark Rivers
Next: Re: EPICS on ARM (continued) emmanuel_mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ChannelArchiver build problem with 3.14.11 on Suse linux Burkhard Kolb
Next: RE: Some Channel Access Questions Jeff Hill
ANJ, 24 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
