1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS on ARM (continued)
To: Dirk Zimoch <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 27 Oct 2010 11:31:00 -0700
Dirk, Rod,
> Normally I don't build on the local machine. But it depends. If it is
> large enough to have the compiler installed and you build locally, then
> your EPICS_HOST_ARCH is linux-arm* and it is not treated as a cross
> build. And you will automatically have caget etc.
That's the 1st thing I tried.
It could potentially work, but you still have to create your configuration files.
iBut when building, it is ... slow. So in a debugging phase, good luck!
> In src/catools/Makefile you find:
> LIBRARY_HOST += catools
> PROD_HOST += caget camonitor cainfo caput
> This builds caget etc only for the host, not for the cross targets.
> To build the tools for all cross Linux IOCs, you may try to add:
> LIBRARY_IOC_Linux += catools
> PROD_IOC_Linux += caget camonitor cainfo caput
I didn't try the above. But I found I simply needed
VALID_BUILDS += Host
in my CONFIG_SITE.Common.linux-arm4vtl
In linux-arm, we already have
VALID_BUILDS = Ioc (which basically means build the libs)
Check configure/RULES_BUILD for more info
Thank you,
Emmanuel
Re: EPICS on ARM (continued) Andrew Johnson
RE: Thread model for EPICS on ARM CPU michael.abbott
Re: Thread model for EPICS on ARM CPU Rod Nussbaumer
EPICS on ARM (continued) emmanuel_mayssat
Re: EPICS on ARM (continued) Dirk Zimoch
Re: EPICS on ARM (continued) emmanuel_mayssat
Prev: RE: EPICS CA problems Jeff Hill
Next: Re: EPICS on ARM (continued) Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS on ARM (continued) Dirk Zimoch
ANJ, 27 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
