1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cygin-x86-debug behavior
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 29 Oct 2010 17:22:17 -0500
On 10/29/10 5:03 PM, Mark Rivers wrote:
> Folks,
> I am trying to run an application built for the cygwin-x86-debug
> architecture, and I am seeing a very strange behaviour.  The
> application run fine, until control returns to the iocsh prompt.  I
> have an epicsThreadSleep at the end of my st.cmd file, so the
> application runs for a while before I get the prompt. As soon as I get
> the prompt it appears that the EPICS threads are hung waiting for
> console input!  If I keep my finger on the Enter key on the keyboard,
> so I keep sending CR characters, the application runs fine.  As soon
> as I release my finger from the key the application freezes!
> If I had to guess what the problem was, I would suspect a problem with
> readline.  Has anyone else run IOC applications under
> cygwin-x86-debug, and if so have you seen this problem?
> Any ideas?
Hi, Mark.
Can you try building w/out readline (e.g. COMMANDLINE_LIBRARY = EPICS)?
 This will help determine whether readline is the problem, and, if
you're still trying to debug the CA problem, would let you get back to
focusing on that for now.
Lewis
cygin-x86-debug behavior Mark Rivers
Prev: RE: cygin-x86-debug behavior Mark Rivers
Next: Re: cygin-x86-debug behavior Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: problem with MCA module (Struck 3820 board), ACQUIRING command Jay Steele
ANJ, 01 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
