1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: cygin-x86-debug behavior
To: "Mark Rivers" <[email protected]>
Cc: [email protected]
Date: Sat, 30 Oct 2010 09:04:44 -0700
Just tested the R3.14.12-rc on linux-x86_64 with COMMANDLINE_LIBRARY = EPICS
The example app builds and runs fine -- no command history, of course.
On Oct 30, 2010, at 7:18 AM, Mark Rivers wrote:
> I changed CONFIG_SITE.cygwin-x86.cygwin-x86-debug  to have the line
> COMMANDLINE_LIBRARY=READLINE
> That caused the application to be built using the readline library, which is apparently not the default for this arch in the distributed version of base 3.14.11.  The application then works fine, it does not hang waiting for console input.
> There appears to be a serious bug in the implementation of console input when NOT using readline.  I would be surprised if this bug only affects cygwin-x86-debug, since that arch is very similar to normal cygwin-x86.  Has anyone tested not using readline on cygwin-x86, linux-x86 or other archs?
> Mark
> ________________________________
> From: Mark Rivers
> Sent: Fri 10/29/2010 6:44 PM
> To: Mark Rivers; Andrew Johnson
> Cc: [email protected]; [email protected]
> Subject: RE: cygin-x86-debug behavior
> I just built base with COMMANDLINE_LIBRARY=EPICS for cygwin-x86-debug.  I get the same behavior as without setting this:
> - readline does not seem to be running, i.e. I cannot recall my last line, etc.
> - The IOC hangs waiting for input from the console.  I can press a button in medm and nothing happens until I hit CR on the console a bunch of times.
> Note that even without setting the COMMANDLINE_LIBRARY flag readline is not being used on this architecture.  I will next try setting COMMANDLINE_LIBRARY=READLINE to explicitly turn it on and see if that fixes the problem.
> Mark
> From: Mark Rivers
> Sent: Fri 10/29/2010 6:35 PM
> To: Andrew Johnson
> I just looked carefully at the build output before I made any changes to base.  I am building cyginx-86-debug as a cross-compile of cygwin-x86, since this is what is supported in base 4.11.
> Here is the output when it builds for cygwin-x86. Note that it is linking with readline and curses.
> g++ -o dxpApp.exe -static -Lj:/epics/devel/dxp-3-0_handel_1_1_4/lib/cygwin-x86 -L/corvette/home/epics/devel/areaDetector-1-6/lib/cygwin-x86
> -L/corvette/home/epics/devel/asyn-4-14/lib/cygwin-x86 -L/corvette/home/epics/devel/autosave-4-7/lib/cygwin-x86 -L/corvette/home/epics/devel/
> busy-1-2/lib/cygwin-x86 -L/corvette/home/epics/devel/calc-2-8/lib/cygwin-x86 -L/corvette/home/epics/devel/mca-6-12-1/lib/cygwin-x86 -L/corve
> tte/home/epics/devel/seq-2-0-12/lib/cygwin-x86 -L/corvette/home/epics/devel/sscan-2-6-6/lib/cygwin-x86 -L/corvette/usr/local/epics/base-3.14
> .11/lib/cygwin-x86       -m32               dxpMain.o dxp_registerRecordDeviceDriver.o    -ldxp -lhandel -lmca -lasyn -lcalc -lsscan -lautos
> ave -lbusy -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lNDPlug
> in -lADBase -lnetCDF -lcalc -lbusy -lsscan -lautosave -lmca -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -l
> registryIoc -ldbStaticIoc -lca -lCom -llibNeXus.dll -llibGraphicsMagick++ -llibGraphicsMagickWand -llibGraphicsMagick -lliblcms -llibpng14 -
> llibbz2 -llibfreetype -llibtiff -llibjpeg -llibjbig -llibz -llibxml2.dll  -lDLPORTIO -lPlxApi -lsetupapi -ltirpc -ltirpc -lGdi32 -lpthread
> -lreadline -lcurses -lm
> Here is the output when it builds for cygwin-x86-debug.  Note that it is NOT linking with readline and curses, but I have done nothing in my base configuration to turn off readline.
> g++ -o dxpApp.exe -static -Lj:/epics/devel/dxp-3-0_handel_1_1_4/lib/cygwin-x86-debug -L/corvette/home/epics/devel/areaDetector-1-6/lib/cygwi
> n-x86-debug -L/corvette/home/epics/devel/asyn-4-14/lib/cygwin-x86-debug -L/corvette/home/epics/devel/autosave-4-7/lib/cygwin-x86-debug -L/co
> rvette/home/epics/devel/busy-1-2/lib/cygwin-x86-debug -L/corvette/home/epics/devel/calc-2-8/lib/cygwin-x86-debug -L/corvette/home/epics/deve
> l/mca-6-12-1/lib/cygwin-x86-debug -L/corvette/home/epics/devel/seq-2-0-12/lib/cygwin-x86-debug -L/corvette/home/epics/devel/sscan-2-6-6/lib/
> cygwin-x86-debug -L/corvette/usr/local/epics/base-3.14.11/lib/cygwin-x86-debug       -m32               dxpMain.o dxp_registerRecordDeviceDr
> iver.o    -ldxp -lhandel -lmca -lasyn -lcalc -lsscan -lautosave -lbusy -lseq -lpv -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -la
> sIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lNDPlugin -lADBase -lnetCDF -lcalc -lbusy -lsscan -lautosave -lmca -lasyn -lrecIoc -lso
> ftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -llibNeXus.dll -llibGraphicsMagick++ -llibG
> raphicsMagickWand -llibGraphicsMagick -lliblcms -llibpng14 -llibbz2 -llibfreetype -llibtiff -llibjpeg -llibjbig -llibz -llibxml2.dll  -lDLPO
> RTIO -lPlxApi -lsetupapi -ltirpc -ltirpc -lGdi32 -lpthread    -lm
> So maybe the problem is the opposite of what I thought, and readline is not being use and that is causing the problem?
> Mark
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Fri 10/29/2010 5:40 PM
> To: Mark Rivers
> On Friday 29 October 2010 17:21:05 Mark Rivers wrote:
>> I was about to add the flag
>> to CONFIG_SITE.cygwin-x86.cygwin-x86-debug.
>> If I do that how much of base do I need to rebuild?
> I think just libCom.  It will then want to re-link all of its executables in
> the other directories, but I don't think it's essential that it do that.
> Good luck, I have to leave now.
> - Andrew
> If a man is offered a fact which goes against his instincts, he will
> scrutinize it closely, and unless the evidence is overwhelming, he will
> refuse to believe it.  If, on the other hand, he is offered something
> which affords a reason for acting in accordance to his instincts, he
> will accept it even on the slightest evidence.  -- Bertrand Russell
Eric Norum
[email protected]
cygin-x86-debug behavior Mark Rivers
Re: cygin-x86-debug behavior Andrew Johnson
RE: cygin-x86-debug behavior Mark Rivers
Prev: RE: cygin-x86-debug behavior Mark Rivers
Next: Re: cygin-x86-debug behavior Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 30 Oct 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
