1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: epics3.14.8.2 problems on win32-x86
To: <[email protected]>
Date: Mon, 1 Nov 2010 19:23:54 +0800
Hi All,
I can install EPICS BASE 3.14.8.2 on win32-x86, but when I executed "makeBaseApp.pl -t example example" and "makeBaseApp.pl -i -t example example" to create a epics application, no files or directories had been generated and no error information appears.
I use Visual C++6.0,Perl 5.8.7 and gnu make 3.81. before installing base, I have changed the following three files:
1. In <base>/configure/RULES_BUILD,I edit "$<*" to "$<" in order to avoid the error "Can't find file 'Com.dll*'" when compiling base.
2. In <base>/src/gdd/dbMapper.cc, I edit the second "int i" to "int j" in the following code, in order to avoid the error "error C2374:'i':redefinition;multiple initialization" when compiling base.
   for ( int i=0; i < db->no_str; i++ ) {
         enumStringTable.getString ( i,
             &(db->strs[i][0]), MAX_ENUM_STRING_SIZE );
         for ( int i = db->no_str; i < MAX_ENUM_STATES; i++ ) {
                 db->strs[i][0] = '\0';
3. In <base>/src/makeBaseApp/makeBaseApp.pl ,I edit "$epics_base =~ s|(/.*)/bin/.*makeBaseApp.*|$1|;" to "$epics_base =~ s|^(.*)/bin/.*makeBaseApp.*|$1|;" in line 173, and add "elsif ($^O eq 'MSWin32') { $newpath =~ s|\\|/|go; }" in line 484. Otherwise, "Can't find EPICS base" when executing makeBaseApp.pl.
Now that no error occurs, why no files generated when makeBaseApp? It's very strange, does anyone have met this problem?
Lin Wang
RE: epics3.14.8.2 problems on win32-x86 Mark Rivers
Prev: RE: Adding readback zeroing to an asyn analog input Angus Gratton
Next: RE: epics3.14.8.2 problems on win32-x86 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 01 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
