1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Adding readback zeroing to an asyn analog input
Date: Mon, 01 Nov 2010 14:12:48 +1100
On Sun, 2010-10-31 at 20:56 -0500, Mark Rivers wrote:
> - You make a bo record zeroing the position.  It does 2 things:
>  *snip*
Hi Mark,
Thank you. This was actually exactly what I first came up with as well,
but then I thought "no, that's way too hacky".
OTOH, if you think it's not too hacky then maybe I'll do just that. It's
certainly a lot less implementation overhead than running a full motor
record (that we really don't need.) So it will probably be equally
maintainable in the long run.
Thanks again,
- Angus
Adding readback zeroing to an asyn analog input Angus Gratton
RE: Adding readback zeroing to an asyn analog input Mark Rivers
Prev: RE: Adding readback zeroing to an asyn analog input Mark Rivers
Next: epics3.14.8.2 problems on win32-x86 王林
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 01 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
