1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: epics3.14.8.2 problems on win32-x86
To: "'Mark Rivers'" <[email protected]>, "'??'" <[email protected]>, <[email protected]>
Date: Mon, 1 Nov 2010 08:55:43 -0600
> I don't know about edit 2.
Edit two appears to be already incorporated in the latest
version of base.
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Mark Rivers
> Sent: Monday, November 01, 2010 6:18 AM
> To: ??; [email protected]
> I suspect that your problem could be with the version of "make" you are
> using.  There are multiple versions called "3.81", but the newer one that
> comes with Cygwin does not work.  You can get a working version here:
> http://cars9.uchicago.edu/software/pub/make.gz
> Unzip that file into the cygwin /bin directory.
> I don't think edits 1 and 3 that you did should be done, those are
> probably because of the problem with make.  I don't know about edit 2.
> Mark
> From: [email protected] on behalf of ??
> Sent: Mon 11/1/2010 6:23 AM
> To: [email protected]
> Subject: epics3.14.8.2 problems on win32-x86
> Hi All,
> I can install EPICS BASE 3.14.8.2 on win32-x86, but when I executed
> "makeBaseApp.pl -t example example" and "makeBaseApp.pl -i -t example
> example" to create a epics application, no files or directories had been
> generated and no error information appears.
> I use Visual C++6.0,Perl 5.8.7 and gnu make 3.81. before installing base,
> I have changed the following three files:
> 1. In <base>/configure/RULES_BUILD,I edit "$<*" to "$<" in order to avoid
> the error "Can't find file 'Com.dll*'" when compiling base.
> 2. In <base>/src/gdd/dbMapper.cc, I edit the second "int i" to "int j" in
> the following code, in order to avoid the error "error
> C2374:'i':redefinition;multiple initialization" when compiling base.
>    for ( int i=0; i < db->no_str; i++ ) {
>          enumStringTable.getString ( i,
>              &(db->strs[i][0]), MAX_ENUM_STRING_SIZE );
>          for ( int i = db->no_str; i < MAX_ENUM_STATES; i++ ) {
>                  db->strs[i][0] = '\0';
> 3. In <base>/src/makeBaseApp/makeBaseApp.pl ,I edit "$epics_base =~
> s|(/.*)/bin/.*makeBaseApp.*|$1|;" to "$epics_base =~
> s|^(.*)/bin/.*makeBaseApp.*|$1|;" in line 173, and add "elsif ($^O eq
> 'MSWin32') { $newpath =~ s|\\|/|go; }" in line 484. Otherwise, "Can't find
> EPICS base" when executing makeBaseApp.pl.
> Now that no error occurs, why no files generated when makeBaseApp? It's
> very strange, does anyone have met this problem?
> Thanks,
> Lin Wang
epics3.14.8.2 problems on win32-x86 王林
RE: epics3.14.8.2 problems on win32-x86 Mark Rivers
Prev: Re: epics3.14.8.2 problems on win32-x86 çæ
Next: Re: epics3.14.8.2 problems on win32-x86 Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: epics3.14.8.2 problems on win32-x86 Mark Rivers
Next: monitors received out of order Tim Mooney
ANJ, 01 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
