1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: monitors received out of order
To: <[email protected]>, <[email protected]>
Date: Wed, 3 Nov 2010 09:17:35 +0000
Yes, I agree with Till. Any mechanism which requires the client to
buffer a number of monitors for each subscription and then compare
timestamps is too difficult for the average client. What happens if you
get two events with the same timestamp?
We use this, for example, to recover the state of a system after a
ca_put_callback. I actually think it works virtually all the time
(primarily because VxWorks seems to be better than Solaris or Linux). I
am happy for the mechanism to break if the event queue overflows, but I
would like a client's event queue on the server to be a single
time-ordered FIFO queue, rather than a collection of queue's. However,
the details are probably a bit of a devil.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
-----Original Message-----
[mailto:[email protected]] On Behalf Of Till Straumann
Sent: 02 November 2010 23:54
To: [email protected]
Subject: Re: monitors received out of order
That's an idea but requires a lot of bookkeeping by the application
for supporting something that could be of broader interest.
I could imagine EPICS' subscription mechanism being enhanced with
a feature that lets you subscribe to a set of PVs and then
be notified when all members of the set have updated.
FWIW
-- Till
On 11/02/2010 04:39 PM, Ben Franksen wrote:
> On Dienstag, 2. November 2010, [email protected] wrote:
>> I am not sure what to do about it now, but I definitely have a
>> frequent requirement to get a coherent set of data from a server. Up
>> till now, I have monitored everything and then taken a snapshot
>> whenever I got a monitor from the last item in a processing chain
>> (which I have ensured always updates whenever the chain processes).
>> This has seemed to work with VxWorks servers. I would like to still
>> be able to achieve the same effect. How else can I do this?
> I think there is one reliable way that should work, although I have
not
> tested it. Please correct me if I am making wrong assumptions.
> The idea is that all the records in your set use TSEL to point to
> the 'start' record of your processing 'queue'. If the records in your
> set are linked via FLNK, they now should all exactly agree on their
> timestamp for one processing run. Then, in your client, you can group
> events according to timestamp, i.e. you first wait for an event with a
> new timestamp, remember it, and then wait until all the other slots in
> your set have been filled by subsequent events with the same
timestamp.
> If your event groups are not clearly separated in time, i.e. different
> event groups may overlap, you can add a small queue (2 or 3 elements)
> of PV sets to be filled. Then the event handler can put values into
the
> right bucket (queue element) according to timestamp.
> Cheers
> Ben
Re: monitors received out of order Ralph Lange
monitors received out of order Tim Mooney
RE: monitors received out of order Jeff Hill
RE: monitors received out of order nick.rees
Re: monitors received out of order Ben Franksen
Re: monitors received out of order Till Straumann
Prev: Re: FW: write failure occuring in writeScanRecInProgress function (after writing header) in saveData.c (sscan-2-6-6 module) Tim Mooney
Next: RE: making edm draw the desired related display based on value of a PV tom.cobb
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: monitors received out of order Till Straumann
Next: Re: monitors received out of order Ralph Lange
ANJ, 03 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
