If I've understood this correctly, there are 2 ways you can do this:
1) Use (560) menu muxes on the top level screen. Point each menu mux to
the PV that provides $(MODE) as an integer value, and get it to populate
a macro that is used to launch the correct related display for that
trigger
2) Make a pdu_trig_generic.edl display with contains only an embedded
window, and get all the related displays to launch this. Make this
embedded window use a menu source, and point the PV to an mbbo that has
$(MODE) as its value for that trigger. You can then fill in the 4
entries in the embedded window with edm screens for your 4 modes
Personally I'd choose option 2.
Tom Cobb,
Diamond Light Source Ltd.
Diamond House
Harwell Science and Innovation Campus
Didcot
Oxfordshire
OX11 0DE
Tel +44 (0) 1235 778582
> -----Original Message-----
> From: [email protected]
> [mailto:[email protected]] On Behalf Of Dayle Kotturi
> Sent: 02 November 2010 22:56
> To: [email protected]
> Subject: making edm draw the desired related display based on
> value of a PV
> Hello,
> In our timing system, there are four possible modes of
> triggers. I want
> to display all 560 triggers the same way, putting their names
> as the label
> on related display widget buttons, regardless of the mode of
> the trigger.
> When the user clicks on the trigger name, a generic related
> display is
> passed the trigger name and mode as macros. The generic display
> contains an embedded window widget which draws the appropriate "form",
> in "Display Source", by mangling the name of the
> mode-appropriate display
> name for "Display File Name" via pdu_trig_$(MODE).edl into one of the
> four possible filenames.
> This is all ok, but it means I have to have to hardcode the
> definition of
> $(MODE) into the macros for each trigger.
> Is there a way that I can display the correct edl file based
> on the value
> of a PV of the MODE at runtime? The modes are not going to be
> changing between
> boots.
> I had envisioned drawing all four related displays and then
> using visibility
> rules, but related display widget does not have visibility
> rule option. I don'tknow if they can be "grouped" to widgets
> that do have this option.
> thanks for any help,
> Dayle Kotturi
> [email protected]
> Controls Department
> SLAC National Accelerator Laboratory
- making edm draw the desired related display based on value of a PV Dayle Kotturi
RE: monitors received out of order nick.rees
RE: FW: write failure occuring in writeScanRecInProgress function(after writing header) in saveData.c (sscan-2-6-6 module) Mark Rivers
<2010>
2025
2026
Re: making edm draw the desired related display based on value of a PV John William Sinclair
<2010>
2025
2026
