1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: devEtherIP
To: <[email protected]>
Date: Wed, 3 Nov 2010 14:55:10 -0600
All,
Sometime back I mentioned that LANSCE was experiencing a crash
in the Allen Bradley TCP/IP PLC driver (devEtherIP). There were some
maintenance days this week, and I found some time to track down the
cause. Apparently the following race condition is occurring.
o iocInit begins
o device support initialization functions start the drvEtherIP
auxiliary threads (one for each plc)
o when a network message comes back from the plc the drvEtherIP
auxiliary thread calls functions in devEtherIP which call scanOnce.
o scanOnce tries to use the uninitialized "onceQ" ring buffer,
and crashes.
o later, iocInit calls initOnce
o initOnce creates the "onceQ" ring buffer
We are experience the bug in R3.13, but looking at the latest
sourceforge sources I am inclined to suspect that there is also
a race condition vulnerability when the latest runs under R3.14.
Below are the patches I made to the driver. Unfortunately, it was
necessary to create two versions; one for R3.13 and one for R3.14.
We only run this driver on R3.13 IOC's so I have _not_ tested the R3.14
version of the fix; Furthermore, the authors of this driver should
review my fix as they may arrive at a better alternative.
Index: devEtherIP.c
RCS file: /epics/cvs/extensions/ab5550/dev/devEtherIP.c,v
retrieving revision 1.8
diff -r1.8 devEtherIP.c
286a287,302
> static void etherIP_scanOnce ( void * pRec )
>       * astonished to discover that initHookRegister is in
>       * initHooks.h in R3.13, but initHookRegister isnt
>       * in iocCore object file in R3.13, so we resort
>       * to an archaic brute force approach
> #    ifndef HAVE_314_API
>      while ( ! interruptAccept ) {
>          epicsThreadSleep  ( 0.1 );
> #    endif
>      scanOnce ( pRec );
417c433
<         scanOnce(rec);
>       etherIP_scanOnce ( rec );
469c485
<         scanOnce(rec);
539c555
<         scanOnce (rec);
589c605
<         scanOnce(rec);
Index: drvEtherIP.c
RCS file: /epics/cvs/extensions/ab5550/dev/drvEtherIP.c,v
retrieving revision 1.6
diff -r1.6 drvEtherIP.c
25a26,27
> #include "initHooks.h"
1295a1298,1301
> #ifdef HAVE_314_API
> static int databaseIsReady = false;
> #endif
1308a1315,1320
> #ifdef HAVE_314_API
>     if (!databaseIsReady) {
>        epicsMutexUnlock(drvEtherIP_private.lock);
>        return 0;
> #endif
1388a1401,1430
> #ifdef HAVE_314_API
> void drvEtherIP_initHook ( initHookState state )
>     if (drvEtherIP_private.lock == 0) return;
>     if ( state == initHookAfterScanInit ) {
>         epicsMutexLock(drvEtherIP_private.lock);
>         databaseIsReady = true;
>         drvEtherIP_restart();
> #endif
> long drvEtherIP_drvInit ()
>      * in initHooks.h in R3.13, but not in iocCore
>      * object file in R3.13
> #ifdef HAVE_314_API
>     int status = initHookRegister ( drvEtherIP_initHook );
>     if ( status ) {
>         errlogPrintf (
>               "drvEtherIP_drvInit: init hook install failed\n" );
> #endif
>     return 0;
1394c1436
<     long (* inie) ();
>     long (* init) ();
1399c1441
<     NULL
>     drvEtherIP_drvInit
Jeff
______________________________________________________
Jeffrey O. Hill           Email        [email protected]
LANL MS H820              Voice        505 665 1831
Los Alamos NM 87545 USA   FAX          505 665 5107
Message content: TSPA
With sufficient thrust, pigs fly just fine. However, this is
not necessarily a good idea. It is hard to be sure where they
are going to land, and it could be dangerous sitting under them
as they fly overhead. -- RFC 1925
Re: devEtherIP Kasemir, Kay
Prev: Re: 64-bit ioc mca issue Tim Mooney
Next: RE: 64-bit ioc mca issue Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: 64-bit ioc mca issue Mark Rivers
Next: Re: devEtherIP Kasemir, Kay
ANJ, 05 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
