Hello Jeff:
That is a good discovery!
The driver is started when the device support's "init" routine is called
with 'after'=1, to which the app. dev. guide sais:
"This routine is called ... (with 'after'=1) ... after all records are
initialized but before the scan tasks are started".
The issue is that this is the last possible initialization step that a
driver has. The onceQ is initialized in initOnce(), which in turn is called
by scanInit(), which in turn happens _after_ the init(after=1) call to
device support.
For those records that are "Passive" and effectively scanned by changes on
the PLC, I see no better way than what you did to check if maybe the
database isn't ready, yet.
I'll include your changes, inc' the version numbers etc.
Kay
On 11/3/10 16:55 , "Jeff Hill" <[email protected]> wrote:
> All,
> Sometime back I mentioned that LANSCE was experiencing a crash
> in the Allen Bradley TCP/IP PLC driver (devEtherIP). There were some
> maintenance days this week, and I found some time to track down the
> cause. Apparently the following race condition is occurring.
> o iocInit begins
> o device support initialization functions start the drvEtherIP
> auxiliary threads (one for each plc)
> o when a network message comes back from the plc the drvEtherIP
> auxiliary thread calls functions in devEtherIP which call scanOnce.
> o scanOnce tries to use the uninitialized "onceQ" ring buffer,
> and crashes.
> o later, iocInit calls initOnce
> o initOnce creates the "onceQ" ring buffer
> We are experience the bug in R3.13, but looking at the latest
> sourceforge sources I am inclined to suspect that there is also
> a race condition vulnerability when the latest runs under R3.14.
> Below are the patches I made to the driver. Unfortunately, it was
> necessary to create two versions; one for R3.13 and one for R3.14.
> We only run this driver on R3.13 IOC's so I have _not_ tested the R3.14
> version of the fix; Furthermore, the authors of this driver should
> review my fix as they may arrive at a better alternative.
> Index: devEtherIP.c
> RCS file: /epics/cvs/extensions/ab5550/dev/devEtherIP.c,v
> retrieving revision 1.8
> diff -r1.8 devEtherIP.c
> 286a287,302
>> static void etherIP_scanOnce ( void * pRec )
>> * astonished to discover that initHookRegister is in
>> * initHooks.h in R3.13, but initHookRegister isnt
>> * in iocCore object file in R3.13, so we resort
>> * to an archaic brute force approach
>> # ifndef HAVE_314_API
>> while ( ! interruptAccept ) {
>> epicsThreadSleep ( 0.1 );
>> # endif
>> scanOnce ( pRec );
> 417c433
> < scanOnce(rec);
>> etherIP_scanOnce ( rec );
> 469c485
> < scanOnce(rec);
> 539c555
> < scanOnce (rec);
> 589c605
> < scanOnce(rec);
> Index: drvEtherIP.c
> RCS file: /epics/cvs/extensions/ab5550/dev/drvEtherIP.c,v
> retrieving revision 1.6
> diff -r1.6 drvEtherIP.c
> 25a26,27
>> #include "initHooks.h"
> 1295a1298,1301
>> #ifdef HAVE_314_API
>> static int databaseIsReady = false;
>> #endif
> 1308a1315,1320
>> #ifdef HAVE_314_API
>> if (!databaseIsReady) {
>> epicsMutexUnlock(drvEtherIP_private.lock);
>> return 0;
>> #endif
> 1388a1401,1430
>> #ifdef HAVE_314_API
>> void drvEtherIP_initHook ( initHookState state )
>> if (drvEtherIP_private.lock == 0) return;
>> if ( state == initHookAfterScanInit ) {
>> epicsMutexLock(drvEtherIP_private.lock);
>> databaseIsReady = true;
>> drvEtherIP_restart();
>> #endif
>> long drvEtherIP_drvInit ()
>> * in initHooks.h in R3.13, but not in iocCore
>> * object file in R3.13
>> #ifdef HAVE_314_API
>> int status = initHookRegister ( drvEtherIP_initHook );
>> if ( status ) {
>> errlogPrintf (
>> "drvEtherIP_drvInit: init hook install failed\n" );
>> #endif
>> return 0;
> 1394c1436
> < long (* inie) ();
>> long (* init) ();
> 1399c1441
> < NULL
>> drvEtherIP_drvInit
> Jeff
> ______________________________________________________
> Jeffrey O. Hill Email [email protected]
> LANL MS H820 Voice 505 665 1831
> Los Alamos NM 87545 USA FAX 505 665 5107
> Message content: TSPA
> With sufficient thrust, pigs fly just fine. However, this is
> not necessarily a good idea. It is hard to be sure where they
> are going to land, and it could be dangerous sitting under them
> as they fly overhead. -- RFC 1925
- devEtherIP Jeff Hill
Re: Firewall (iptables) issues? Ralph Lange
Options for reviving old Allen Bradley PLC implementations Chestnut, Ronald P.
<2010>
2025
2026
Firewall (iptables) issues? Eric Norum
<2010>
2025
2026
