1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: base 3-14-11 and breakpoint tables for ai and ao
To: EPICS Tech Talk <[email protected]>
Date: Fri, 05 Nov 2010 10:52:22 -0400
On 04.11.2010 21:36, Mark Clift wrote:
Hi All,
I have noticed that breakpoint tables in base 3-14-11 require the table name to be all numeric characters. This appears consistent with line 634 in dbStaticRun.c, where the first non numeric character must be '\0'. However, according to page 105 of the 3-14-11 application developers guide, the breakpoint table name can consist of any alpha-numeric characters. So, there seems a problem here. ? For now, I am renaming my breakpoint tables.
Mark,
line 634 of dbStaticRun.c is code that gets executed when you try to set a (numerical) field of type DBF_MENU or DBF_DEVICE using a string value. Converting a string to a number does require the string to consist of only numeric characters, so I think that code is correct.
Which field of your record are you trying to write the breakpoint table name to?
Ralph
base 3-14-11 and breakpoint tables for ai and ao Mark Clift
Prev: Re: base 3-14-11 and breakpoint tables for ai and ao J. Lewis Muir
Next: Re: Firewall (iptables) issues? Phillip Sorensen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: base 3-14-11 and breakpoint tables for ai and ao Andrew Johnson
ANJ, 05 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
