1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: base 3-14-11 and breakpoint tables for ai and ao
To: [email protected]
Date: Fri, 5 Nov 2010 11:06:15 -0500
Hi Mark,
On Thursday 04 November 2010 20:36:28 Mark Clift wrote:
> I have noticed that breakpoint tables in base 3-14-11 require the table
> name to be all numeric characters.  This appears consistent with line 634
> in dbStaticRun.c, where the first non numeric character must be '\0'.
> However, according to page 105 of the 3-14-11 application developers guide,
> the breakpoint table name can consist of any alpha-numeric characters.  So,
> there seems a problem here. ?  For now, I am renaming my breakpoint tables.
I think I know what might have been confusing you: To be able to select a new
breakpoint table in the LINR field you have to copy the menuConvert.dbd file
from base/dbd into your application's App/src directory (where the IOC's .dbd
file gets created) and add your new table name as a new choice to it.  You can
also delete any of the type* choices if you don't use them, but don't touch or
move any of the first three items.
This is a bit of a pain, so I just wrote a blueprint to look at adding the
table names to menuConvert automatically in future releases.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
base 3-14-11 and breakpoint tables for ai and ao Mark Clift
Prev: Re: Firewall (iptables) issues? Eric Norum
Next: Re: Firewall (iptables) issues? Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: base 3-14-11 and breakpoint tables for ai and ao Ralph Lange
Next: Re: base 3-14-11 and breakpoint tables for ai and ao Mark Clift
ANJ, 09 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
