1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Firewall (iptables) issues?
To: Phillip Sorensen <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Fri, 5 Nov 2010 08:28:12 -0700
To summarize:
If you want channel access clients on a machine to be able to see replies to broadcast PV search requests you need to permit inbound UDP packets with source port EPICS_CA_SERVER_PORT (default is 5064).  On systems using iptables this can be accomplished by a rule like
	-A INPUT -s 192.168.0.0/22 -p udp --sport 5064 -j ACCEPT
If you want channel access servers (e.g. "soft IOCs") on a machine to be able to see clients you need to permit inbound TCP and UDP packets with source port EPICS_CA_SERVER_PORT (default is 5064).  On systems using iptables this can be accomplished by rules like
	-A INPUT -s 192.168.0.0/22 -p udp --dport 5064 -j ACCEPT
	-A INPUT -s 192.168.0.0/22 -p tcp --dport 5064 -j ACCEPT
In all cases the "-s 192.168.0.0/22" specifies the range of addresses from which you wish to accept packets.
Eric Norum
[email protected]
Re: Firewall (iptables) issues? Ralph Lange
Firewall (iptables) issues? Eric Norum
Re: Firewall (iptables) issues? Darren S. Dale
Re: Firewall (iptables) issues? Eric Norum
Re: Firewall (iptables) issues? Andrew Johnson
Re: Firewall (iptables) issues? Phillip Sorensen
Prev: Re: Firewall (iptables) issues? Phillip Sorensen
Next: Re: base 3-14-11 and breakpoint tables for ai and ao Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <2010>  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Firewall (iptables) issues? Ralph Lange
ANJ, 05 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
