1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Options for reviving old Allen Bradley PLC implementations
To: "Chestnut, Ronald P." <[email protected]>
Date: Fri, 5 Nov 2010 21:53:27 -1000 (HST)
Ron,
I was hoping that the people here at the JAC who deal with
the Allen Bradleys more than me would respond but I didn't
see anything of that kind.
We have Allen Bradlays both at UKIRT and at JCMT.
The UKIRT Allen Bradley is definitely using the abdf1
driver, but for all I know the serial line is still
plugged into the 'second' serial line on an hknitro60.
One of our electronics guys and I once made an attempt
to connecgt it via a terminal server because we had 1/2
hour left in the summit day but we don't even really know
whether we had the right pin-out on the cable. I know
I haven't dealt with it since. I also now that we had
and may still have problems with the AB panelview in cold
temperatures (below freezing, and I got some information
on that from Karen White and somebody else at ORNL at the
Brookhaven EPICS meeting, saying basically "you're
operating it out of specs").
Not sure this helps any, but I at least wanted to
put it out there.
Aloha,
Maren
On Fri, 5 Nov 2010, Chestnut, Ronald P. wrote:
We have a number of old Allen Bradley PLC implementations here at SLAC. One of these uses a Data
Communication Card (DCM) in VME is connected to the SLC5 SLC500s. One path we are considering is using
an RSLogix PLC (which has good EPICS support) as the master PLC, and slaving the SLC5 PLC to that. It
turns out that there exists a package to translate the ladder logic from SLC500 to RSLogix.
Another group here is asking the following:
?We have some old SLC 5/04 PLCs from Allen Bradley that we wanted to make EPICS compatible. I found a
third party SLC module that talks Ether/IP:
http://www.prosoft-technology.com/prosoft/products/for_rockwell_automation/platform/slc/mvi46_dfnt
Will this module work to provide the EPICS support? ?
Another piece of information is from Ernest Williams: He warned us against the direct SLC-50x EPICS
driver support, since it uses its own protocol (DFI?) and has a poor reputation and poor support.
So the questions to the community are
How are you reviving old PLC support? What has or has not worked? What do you recommend?
Ron Chestnut
Options for reviving old Allen Bradley PLC implementations Chestnut, Ronald P.
Prev: Re: Options for reviving old Allen Bradley PLC implementations jun-ichi.odagiri
Next: Re: monitors received out of order Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Options for reviving old Allen Bradley PLC implementations Bryce Karnaghan
ANJ, 08 Nov 2010 · Home · News · About · Talk · Base · Modules · Extensions ·
